Bbtb Help
Old Sep 24, 2006 | 10:22 PM
  #21
Teflon's Avatar
Thanks redz I hope thats all its is smile.gif . I'll do it in a day or 2. Thanks for your help im trusting you hail.gif
Old Sep 24, 2006 | 11:39 PM
  #22
Heh, you'll slap yourself afterwards.
Old Sep 24, 2006 | 11:51 PM
  #23
zoned019's Avatar
Vehicle: 97 Tib
And get a Kefico TPS anyway, you're gonna need it regardless.
Old Sep 25, 2006 | 04:51 PM
  #24
Teflon's Avatar
So i did what redz said an im still idleing high! At one point i had my idle down to 1100RPM but when i gave it gas it stayed at 1900PM, now i have a CEL but when i put the stock TB back on i get no CEL WTF!!! mad.gif
Old Sep 25, 2006 | 04:53 PM
  #25
hamhead's Avatar
Well, its not the TPS.
So either you have a vacuum leak or its not adjusted properly. Since you get it to idle properly you probably are doing it ok on the bigger one.
Hence you should probably fix that hole thats in it.
Old Sep 25, 2006 | 05:09 PM
  #26
Yes, after the ecu reset the idle dropped down some. Good. Now adjust the idle.
Go get that CEL checked. Then we can move on.
Old Sep 25, 2006 | 09:52 PM
  #27
Teflon's Avatar
Here's the thing when i push my TPS in hard on one side it idles perfect, but when i rev it it goes back high. but if i keep presure on the tsp it will come down to normal again. Maybe i can hire someone to sit in my engine an hold it all the time lmao.gif I don't know if this has anything to do with the problem, but you know where you contect the TPS on the TB there is a shaft an a copper ring at the bottom, the copper ring on the stock TB is flush with the surface but the BBTB ring is counter sunk in a bit . So i put thr stock TB back on again since i need it for work an it runs perfect
Old Sep 25, 2006 | 10:16 PM
  #28
This is why I warn folks about SR.
Still to this day, they will sell anything available for any car. Folks wonder why Kspec won't sell System BBTB's, it's because 90% of what they make is pure crap quality.
Old Sep 26, 2006 | 09:36 PM
  #29
Teflon's Avatar
Im trying to get my refund from SR. They told me if it's in new condtion that they will issue a refound, but if its used then they won't give me all of my money back!! well the BBTB has marks on it from putting the bolts on because the powder coat comes off so easy. I hope i dont get screwed (I know i will though mad.gif)
I wonder how much money they will give me back if they decide to say that it was in bad condition an screw me?? Well i let you guys know what happens. Im going to send it back this friday
Old Sep 26, 2006 | 09:49 PM
  #30
I wouldn't even bother man. If those assholes are trying to pull that shit, just contact your credit card provider and claim it. You'll get your cash back. if you want, you can send me the BBTB and I'll see if I can fix it. I'll send it back to you, I just wanna see if it's doable.
If nothing else, you'll have your money back and we'll know if these can be fixed.
