Bb Throttle Body Question
Old Apr 6, 2009 | 04:42 PM
UrS0NvS's Avatar
you must drill one hole for the IAC and one tapped hole for the top left hole in the tb.
waiting for pics.
Old Apr 6, 2009 | 04:53 PM
i just stuffed mine with that plumber's epoxy informercial stuff made sure it was smooth, and it works great!
Old Apr 6, 2009 | 04:57 PM
Steezy's Avatar
Vehicle: 99/Hyundai/RD1
sorry it took so long for the pictures, today's my first day as a member, just now gettin use to it.. so here it is
sorry they didn't turn out very good
Here's the link to the pictures in the garage
http://www.rdtiburon.com/index.php?&au...tem&CID=120
Old Apr 6, 2009 | 05:01 PM
UrS0NvS's Avatar
where did you get this TB at?
also, size?
Old Apr 6, 2009 | 05:03 PM
Steezy's Avatar
QUOTE (UrS0NvS @ Apr 6 2009, 07:01 PM)
also, size?
The guy from importshark.com gave it to me, idk the size... he found it randomly in a box somewhere and gave it to me
Old Apr 6, 2009 | 05:09 PM
SR Tech's Avatar
Vehicle: 2011 Tuscon
Looks like a R-side to me, just no name on it.
Also with the beta 2 TB IAC hole....i just stuffed some Fiberal(fiberglass filler) in there, sealed it good.
Old Apr 6, 2009 | 05:17 PM
UrS0NvS's Avatar
SRT...
i find it weird if it was a old R-side that they wouldnt allow room for a nut on the top left hole of the tb. i'm thinking maybe a bored out beta 2 OEM TB, probably 57mm max in size.
Old Apr 6, 2009 | 05:25 PM
Steezy's Avatar
That's what I thought... I just don't want to put to much stress on my engine, i want to keep her healthy, but even if i'm runnin a little rich i'll let it go but if it runs real rich i'll probably just put the stock one back on.. I forgot the other thing I had to do to put this on was this TB didn't have connectors for the coolant hoses, I had to connect them together, which I figure is better for cooler air intake
Old Apr 6, 2009 | 05:38 PM
UrS0NvS's Avatar
depends on the part of the nation you are in if you want to route the coolant through the TB. we have a DIY for the throttle body bypass. just your preference. the DIY explains the reasons for the TB coolant.
I would look into a junkyard to see if you can find a beta2 IM. they will bolt up to your beta1 motor and you wont have that nasty bolt sticking out there in the open, but that is the OCD side of me. also, depending on the size of the tb would also be a factor if i wanted to keep it on my engine.
Old Apr 6, 2009 | 07:48 PM
Steezy's Avatar
Well the DIY says that it's better performance wise for the coolant not to run through the throttle body, and since I live in Ohio I doubt my butterfly will freeze shut, so I'm glad my friend told me to not run it through the TB... thanks everyone for helpin me out, much appreciated!
