is anyone out there making real power?
Old Aug 19, 2002 | 01:40 AM
  #31
Red's Avatar
Red
Nope, but it appears that I'm going to be fairly close to the lead for that "honor" of ripping apart a $1200 diff and voiding the warranty.
I talked with my contact at Quaiffe for several weeks before we came to this conclusion. We actually had some help with the guys from KAAZ in this...
Old Aug 19, 2002 | 01:42 AM
  #32
jonzor's Avatar
random_ what will you be doing about timing and spark? what a bout axels also?
Old Aug 19, 2002 | 01:49 AM
  #33
Red's Avatar
Red
Timing, spark = haltech
Old Aug 19, 2002 | 03:33 AM
  #34
Stormtrooper's Avatar
Vehicle: 2003 Accent
You want real power? Check out this one. Onpol
Old Aug 19, 2002 | 03:36 AM
  #35
Jon's Avatar
Jon
Sorry for the late response im running the setup from Alpine developments there are a few bugs that need to be worked out with the system mainly with the programme in the unichip but hopefully they will all be sorted in October after the retune. The intercooler is front mounted and as for the manifold its a bllody heavy as hell cast of that alpine make themselves but it came with the kit and untill i have more cash it will have to do.At the mo the ps is abot 8 but hopefull it will be put up a little when i get it tuned not sure what to go upto as all my internals are still stock.
Old Aug 19, 2002 | 05:03 AM
  #36
jonzor's Avatar
thanks for the link. thats the kind of stuff im looking for. the diff was bad news though! so what is the price range of a haltec unit? can u controll air/fuel with it also?
Old Aug 19, 2002 | 05:50 AM
  #37
Red's Avatar
Red
The Haltech unit entirely replaces the stock computer, sensors and associated wiring. When you are finished, you can program in whatever the hell you want for fuel delivery, ignition timing, injection timing, injection mode (batched, sequential, multipoint, semisequential, staged), ignition method (direct fire, waste spark, distributor, toggle ignitor), rev limit and a gazillion other things.
It is also capable of controlling thermal fans (radiator fan, AC condensor fan, intercooler fan), programmable nitrous control, multiple boost maps for electronic boost control, idle speed control, closed loop (O2 sensor-based) fuel control for passing emissions and saving gas, secondary staging rev limit control, fuel / ignition / boost trim input, external shift lite and tachometer output and another gazillion things.
I've only listed the features that are most pertinent to our cars; the Haltech has enough features to make you sick of reading.
The brain, software, unterminated wiring harness and basic sensors (intake temp, coolant temp, TPS, 3-bar MAP) go for around $1200USD give or take.
Once you have the parts, you can either pay someone else for the install (guess about $1000 give or take) or do it yourself (plan on about a week of having the car absolutely gutted to the floorboards and firewall)
This isn't a tool for someone who wants weenie horsepower. If all you want is some mediocre boost, stay with the bolt-on parts. If you are wanting to make the best of a $10,000 buildup project, this is the part you want to use.
Old Aug 19, 2002 | 05:53 AM
  #38
Red's Avatar
Red
Apologize for the second post, but as an aside, my website should FINALLY be working just a bit later today.
If you are interested in the Haltech installation, you should be able to view it shortly on my website: http://www.hyundaiproject.com
I apologize to all who have been waiting for my website to become available; I have finally flipped off my past service provider and switched over to DixieSys for my website needs. I've got 400mb of storage and 7.5gb of bandwidth to burn per month, and these guys have a MUCH better track record versus the losers I had.
Joel has agreed to help me put together a technical forum, which (as you can see a little later wink ) doesn't exist yet. Hopefully with some PHP integration, you guys can keep up with my project and the issues I'm currently tackling interactively from that site.
Old Aug 19, 2002 | 03:09 PM
  #39
MechaniX_034's Avatar
Vehicle: Lancer Evo IX
Sounds like I just found the necessary hardware. Any output limits on the Haltec unit Red?
Old Aug 19, 2002 | 07:09 PM
  #40
lantraluvr's Avatar
Vehicle: 1999 Elantra
Mechanix, what do you need the Haltech for?
