adjustable cam sprockets
Old Dec 23, 2004 | 10:18 AM
mb1604's Avatar
Default Re: Hyundai's in Rally
no dyno picture.... so i should just get the exhaust one then?
Old Dec 23, 2004 | 12:26 PM
FordFasteRR's Avatar
Default Re: My ride - '01 Tiburon
QUOTE (mb1604)
what dyno picture? (Do you mean that you dont have a dyno in your area? ), or do you mean that you can't see my dynos that i posted on this thread?
and what exhaust one ? do you mean installing the kspec cam gear under the valve cover only on the exhaust cam ?
or do you mean installing the obx cam sprocket on the timing belt side like I did ?
sheesh.. please be a little more descriptive with your questions...
Old Dec 23, 2004 | 01:08 PM
mb1604's Avatar
Default Re: For the ass lovers!!!
ya your dyno results werent showing but now they are, ya and i meant exhaust cam sprocket, the obx one, just get that one? and about how much are dyno tests?
Old Dec 23, 2004 | 01:40 PM
Default best nitrous system
QUOTE (mb1604)
the obx cam sprocket is directly attached to the exhaust cam, however the exhaust cam is coupled to the intake cam via a chain on the drivers side of the head beneath the valve cover..
so if you use the obx cam sprocket to tune your cams you are in fact adjusting the phase of both cams at the same time.
Old Dec 23, 2004 | 04:42 PM
how stable is the OBX sprocket? I habe heard some horror stories about cheap adjustables slipping.
Old Dec 23, 2004 | 05:35 PM
TibRacer01's Avatar
Default Re: The Person Above You
QUOTE (Dweet)
well there is one sprocket and udner the valve cover there is just the cams that are connected by chain
From what I remember, there is 1 that the timing belt is around, and then there is 1 for each cam under the valve cover.
Old Dec 23, 2004 | 08:18 PM
QUOTE (Mad-Machine)
the little bolts that it uses are no good. you should go to home depot and replace the original allen wrench socket bolts with new steel bolts ... total cost to replace the bolts ist about 1 dollar.
thats what I did.......
_____________
QUOTE (TibRacer01)
Thanks for clarifying what everyone else on this thread has already clarified.............
Old Dec 24, 2004 | 08:18 AM
Default Re: Gaugeillumination Position search
ok, that makes sense on the bolts. Thanks!
