4 Grand Idle.. Help :(
MOD EDIT PLEASE DONT QUOTE POST ABOVE YOURS
I bought my tps off of someone on here awhile back and when i got home to put it on the harness and the tps clip things wouldn't go on right. It was awhile ago though.
QUOTE (Tank @ Aug 6 2007, 07:42 PM)
The reason it is glued is because i replaced my Dae sung tps and the sensors didn't have the same clips so i had to cut part of the TPS to have it fit, it stayed glued there (gorilla glue) for over a year with no problems. I removed the IAC sensor and it caused the idle to drop to 3000.
How about you replace my current BBTB and TPS? zoned
Adjusting the throttle cable doesn't change the idle.
You need to disconnect the IAC, then adjust the idle to 850 without the a/c on. Then plug in the IAC again. If that dosn't work, you need to search for a vacuum leak on your manifold, or get a new manifold. Between the IAC (ECU adjusted) and the TB (manually adjusted), the car will keep it's idle at 850. If you turn down the idle while the car is on, it will work or something is broken.
