2001 Cmp Sensor And Evap Purge Valve Codes Gotta Get Fixed
No thanks Krazy, just curious.
If it's a loose gas cap, tightening it so it clicks at least 3 times, then driving for three drive cycles, it will go away by itself.
You can also pull the main kill (the big white bar with 2 fuses under it) and the ECU fuse from the fuse box to achieve instant gratification. Another method is to disconnect the negative battery terminal for 1 minute.
