The New 1.8 Cam Install
Old Oct 29, 2008 | 01:00 PM
  #61
likeyoumeanit's Avatar
okay, so I am fine, my marks are just f'd up right?
Old Oct 29, 2008 | 01:04 PM
  #62
Dang I was going to say it was right last night but I thought I might have been too tired and not counting the links right
If it lines up properly it's right.
Old Oct 29, 2008 | 01:18 PM
  #63
anyone else notice the before and after chain tension?
SOMETHING is wrong.
  #64
SCORE!!! I didn't screw up after all
Old Oct 29, 2008 | 02:44 PM
  #65
Chain tension: when it's slack, note the position of the cam retainer/caps...
...not on there. It's normal to have a slack chain at that point.
Old Oct 29, 2008 | 02:56 PM
  #66
In the Before picture, when everything was okay, there is no slack, in the after picture, now that there is problems, there IS slack, you say that is normal?
Old Oct 29, 2008 | 03:19 PM
  #67
^^^ in the before picture all I had done was pop the caps off, in the after picture it hasn't been seated , I had just got the chain on, it tightened up when I put the caps back on
Old Oct 29, 2008 | 03:31 PM
  #68
Yes it's normal. The valve springs kick the replacement cam out of position and there will be slack. Tighten down the caps and it goes tight. It's pretty scary the first time you change cams out!
  #69
I was looking at just the chain and sprockets. I can understand that then. is it all running fine?
I also got you confused with Daneeboy that's having all those issues.
Old Oct 29, 2008 | 03:51 PM
  #70
yeah, it's running great, that's why I was surprised when people were saying I messed up
