Installing A Oddessey Pc 680 Battery
Old Sep 14, 2005 | 10:34 PM
tibbytib's Avatar
This sounds like a great idea. Please correct me if I'm reading this wrong, but I checked on Webtech and it says that the battery needs to put out at least 420 cold cranking amps. I believe this smaller battery is only rated at about 300 cold cranking amps. Since I live in Colorado where it can get pretty cold, should this be a concern?
Old Sep 15, 2005 | 06:07 PM
brian01tib's Avatar
I live in FL and not used to cold but i play cds while studying and with friends for about 30 mins and have never had a problem starting up, i thought it was 680 cca but im not sure sorry
Edit yea it is 680 cca
Old Sep 15, 2005 | 06:33 PM
little hint
the cca on oddessey batteries are part of the part number on most of there batteries there are few exeptions though
Old Sep 16, 2005 | 01:19 AM
fonseca's Avatar
That's a neat size. You could easily install two in the stock location, one for cranking and the car's needs, and the other for ICE. I was ready to buy a blue top, but I think I'll look into this battery first.
Old Oct 3, 2005 | 08:56 PM
undacovatib's Avatar
Vehicle: 1997 Hyundai Tiburon
might be a dumb question: will this meet all the necessary requirements needed for the car to run right?
Old Oct 3, 2005 | 09:06 PM
It's a very dumb question. Read the thread, or search.
Old Oct 4, 2005 | 04:49 PM
brian01tib's Avatar
^^^ lmao.gif haha.gif Seems like someone should put at the top of every page SEARCH it saves everyones time.
My car is still running fine.
The reason for the install is for weight saving purposes, not for huge systems, I ran the tib with lights on and the stock stero all the way up with no problems
Old Feb 14, 2006 | 09:39 AM
JonGTR's Avatar
I just bought an Odyssey 680 battery for $68 shipped off ebay!!!! fing02.gif
To recap the differences:
I have an Optima Red Top 850cca, but its 41lbs with a dimension of 10x7x8.
The Odyssey only weights 14lbs, and has a dimension of 7x7x3.
Thats a weight savings of 27lbs for only $68!!!!!!!!1!!!!!1
Any kind of weight reduction that doesn't involve gutting the car like the Honda fags is awesome!!!! hail.gif
Old Feb 14, 2006 | 01:39 PM
dquicksta's Avatar
these batteries are great... if you like stinger batteries then check these out instead, they I do believe are the batteries stinger "resells" as their own. I have had one ever since my optima crapped on me, and have not had any problems whatsoever with my car, or my audio system.
Old Feb 14, 2006 | 02:21 PM
brian01tib's Avatar
It was 28 this morning yea my car had ice all over it. It started fine so it starts in 28F weather lowest its been here in 13 months or something so IDK how cold it will start.
