DIY: The "Big 3" wire upgrade
Old Dec 23, 2004 | 08:47 AM
  #31
krazykyle's Avatar
Default Inconsistancies
pictures are down on the original post.
Old Dec 23, 2004 | 09:43 AM
  #32
spiceflow's Avatar
Default Tiburon Calendar
They work fine for me.
Old Dec 23, 2004 | 09:52 AM
  #33
krazykyle's Avatar
Default Re: The "I hate winter thread"
There they are.
Old Dec 30, 2004 | 09:06 AM
  #34
Supermanwoot's Avatar
Default Re: Being sick
so does anyone have an alternative route for the alt grounding point. Are you saying to run the line from the alt to the firewall ground point or the positive battery terminal to the firewall ground?
Old Dec 30, 2004 | 01:45 PM
  #35
tibwrcsbj's Avatar
Default Re: Bigtime electrical Problems HELP PLEASE
The alternator should be run to the Battery POSITIVE terminal.
Add another wire from the BATTERY NEGATIVE to the firewall ground is what shadohh was trying to say.
Old Dec 30, 2004 | 01:49 PM
  #36
Default Re: DIY - The "big 3" wire upgrade
however, shadoh mentioned fusing the connection to the battery positive terminal. How can this be done?
Old Dec 31, 2004 | 10:37 AM
  #37
djshaggy's Avatar
Default Re: I need advice..
you could easily put an inline fuse like you would for your amp power wire.
What I did was put in a 100 amp circuit breaker so if (for some strange reason it blows) all I have to do is flip the breaker back on and not replace a fuse.
Old Feb 17, 2005 | 02:22 AM
  #38
tibbytib's Avatar
So, has anyone had problems adding the extra cable from the Alternator to the Battery? I want to begin this project, but would like to know peoples reactions to this particular upgrade. I'm new here, so if this has already been discussed, I appologize.
Old Feb 18, 2005 | 11:20 PM
  #39
Alex01tib's Avatar
i was wondering about this too, its the only thing really holding me back from doing this.. i think that shadohh was saying that if you leave the stock wire from ALT-Batt(+) in additon to the New 0-gauge wire, then it will retain its sensing ability and there will be no problem, but im not 100% sure..
Old Feb 20, 2005 | 07:09 PM
  #40
spiceflow's Avatar
You should definitely leave the stock wires in place. Electricity always follows the path of least resistance, so having them in there will not hurt you at all. In fact removing them will hurt current flow, and may cause problems as stated.
