Converting To Push Style Clutch
the only thing that will hold about 15 and 20 psi is what i am using there is a korean compay makeing a twin plate clutch but it ant cheap but its a 1000 dollors less then mine
ok so im still lost on what clutches we can use. im looking at putting a turbo on my car and know i need somthing better. there are clutch kits on ebay but im sure they are crap and they are still pull type. any info?
i think having the list of the part we need some pic and list of clutch that would fit.... would be nice sad.gif
theres a couple ways to do this conversion.. theres only a couple people that have done it that i know of. t4turbotib (hes gone now from site pretty much) mad john, and demon fox ( i have seen his in person) demon_fox (dan) can get conversion kits made up for a decent price. i would contact him.
although, the stock pull style system is fine, just need a beefy clutch.. most of the big higher hp guys have a pull style clutch.
quite simple..
you need the fork,lever, bearing, retainer and bushings
then you can bolt on a non turbo dsm clutch ACT do make pretty good ones for those application
or you can modify your flywheel and use the dsm turbo clutch
on a side note, i still have to push conversion kit on hand
