Accent LC beta swap DIY:
Old Dec 20, 2009 | 12:02 AM
  #21
Schwitzer Turbo's Avatar
Vehicle: 1995 Scoupe Turbo GTR
<div class='quotetop'>QUOTE (patdeman @ Dec 2 2009, 08:45 PM) <{POST_SNAPBACK}></div><div class='quotemain'>so if i understand correctly, i can use my 1.5L trans, with an scoupe turbo clutch and pressure plate, with the 1.5L throwout bearing and the 2.0L flywheel ?</div>
can we please get a confirmation on this? Im not sure if i read correctly but the information above does differs from the original post (sorry my english not so great) ps this is a GREAT Post! Thumbs up!
Old Dec 20, 2009 | 02:09 PM
  #22
I think that's all right, not 100% sure about the throwout bearing but I think so. The rest is right for sure.
Old Dec 20, 2009 | 03:57 PM
  #23
warp21's Avatar
Vehicle: 2000 Hyundai Accent
I used an oem 93-95 Scoupe turbo clutch and pressure plate with an Accent throw out bearing in my swap.
Old Dec 20, 2009 | 04:15 PM
  #24
<div class='quotetop'>QUOTE (warp21 @ Dec 21 2009, 12:57 AM) <{POST_SNAPBACK}></div><div class='quotemain'>I used an oem 93-95 Scoupe turbo clutch and pressure plate with an Accent throw out bearing in my swap.</div> does a accent and a scoupe have the same throwout bearing?
And does the clutch ever slip when snap changing-racing?
Old Dec 20, 2009 | 04:19 PM
  #25
warp21's Avatar
The one that came with the kit was totally different than the one that was in my Accent. I shift my car without lifting off of the throttle (Megasquirt launch control hooked the the clutch pedal) and so far it does not slip.
Old Dec 22, 2009 | 01:38 PM
  #26
I when to the clutch suppliers and looked up the release bearing manufacture NSK for the scoupe And there was no listing for scoupe only accent(g4ek). And the product id was the same as the j2. So im pretty confident it will work
Old Dec 22, 2009 | 04:29 PM
  #27
warp21's Avatar
This is the release bearing that was in my Accent.
This is the one that was in the Scoupe clutch kit.
Old Jan 16, 2010 | 08:27 PM
  #28
patdeman's Avatar
Vehicle: 2000 hyundai accent GS 1.5L
ive been readin french forums and in quebec the swap is very popullar, but they use the accent 1.6L clutch and pressure plate ? why havent we been using this ? also they have a way to use the 1.5L or the 2.0L starter with slight mods.
Old Jan 23, 2010 | 10:46 AM
  #29
jsharptooth91's Avatar
Vehicle: 2002 Accent 2.0L
I cant answer why were using the scoupe over the 1.6 accent clutch. Maybe its personal pref. Both should work
My 1.5 starter had no issues installing. I dont know what mods they are talking about. It was PnP
Old Jan 23, 2010 | 04:04 PM
  #30
patdeman's Avatar
when you install the 2.0L starter, u have to do something with the bracket for the shift linkages because they would be in the way i think. from what ive heard the 2.0L engines is hard on the 1.5L starter.
