Accent LC beta swap DIY:
Old Mar 5, 2009 | 09:04 AM
slyderdai's Avatar
<div class='quotetop'>QUOTE(mick211 @ Mar 4 2009, 10:14 PM) </div><div class='quotemain'>Hey about the clutch .. Did you use the elantra pressure plate ? Becaus right now i have the 2l flywheel and 1.6 clutch and pressure plate and its not working .. the presssure plate seems a little too small .. thanks</div>
I think he's using the scoupe turbo (1.5) Clutch and pressure plate.
What do you mean it's not working???
Old Sep 14, 2009 | 03:47 PM
sassan's Avatar
Vehicle: 2000/Hyundai/Accent
can anyone tell me where i can get the pass. motor mount so i can do this swap. the only thing is i have a 2000 accent and a 2001 Elantra and i wanna know were i can go to get the engine mount?
Old Sep 14, 2009 | 04:09 PM
Beta Swap Shop use to sell them, but I don't think they do anymore. You will probably have to make one yourself or have it made.
Old Sep 14, 2009 | 11:21 PM
sassan's Avatar
<div class='quotetop'>QUOTE (187sks @ Sep 14 2009, 06:09 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Beta Swap Shop use to sell them, but I don't think they do anymore. You will probably have to make one yourself or have it made.</div>
ok so i will have to have one made for the car right? so about how much will that run me about to just get the mount made. and wen u do this swap do u still have room to put in A/C?
Old Sep 15, 2009 | 10:47 AM
It would depend on what a fab shop would charge you. Basically you can cut off the round part of your mount and weld on a piece of square stock and drill some holes. It's pretty easy, but it'll have to be made with the Beta sitting in the car to get the measurements from.
Old Sep 23, 2009 | 07:45 PM
patdeman's Avatar
Vehicle: 2000 hyundai accent GS 1.5L
can i use my 2000 1.5L accent trans, clutch and pressure plate ?? what if i use the accent flywheel ?
(i just bought a new stage 1 clutch and dont wanna buy another one)
Old Sep 23, 2009 | 08:58 PM
Your trans will work, but you'll need a 1.6l Accent clutch & pressure plate and the 2.0l flywheel.
I have heard that the 1.5l Accent clutch does not work, but I don't know the specific reason why. The 1.5l Scoupe Turbo clutch also works.
Old Sep 23, 2009 | 09:33 PM
jsharptooth91's Avatar
Vehicle: 2002 Accent 2.0L
<div class='quotetop'>QUOTE (187sks @ Sep 23 2009, 07:58 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Your trans will work, but you'll need a 1.6l Accent clutch & pressure plate and the 2.0l flywheel.
I have heard that the 1.5l Accent clutch does not work, but I don't know the specific reason why. The 1.5l Scoupe Turbo clutch also works.</div>
I used the scoupe turbo clutch. The 1.5L accent clutch will NOT work. Its smaller than the flywheel. With using the scoupe clutch you will not be able to use the throw out bearing. (Diff type). You need a throw out bearing that work with the tranny, which is a 1.5.
Im not sure on how or the diff between the 1.6 clutch and the scoupe clutch. I just know what worked for me.
Old Sep 24, 2009 | 05:11 AM
patdeman's Avatar
but what if i mount the 1.5L accent flywheel to the new engine ? can i do that ?
Old Dec 2, 2009 | 11:45 AM
patdeman's Avatar
so if i understand correctly, i can use my 1.5L trans, with an scoupe turbo clutch and pressure plate, with the 1.5L throwout bearing and the 2.0L flywheel ?
