spring compressor??
Old Apr 4, 2003 | 06:00 AM
ONLY1DB's Avatar
Default spring compressor??
just wondering where to get one and how much it would be....i'm gonna hop onto ebay....but any responses would be great!!!
Old Apr 4, 2003 | 06:02 AM
ONLY1DB's Avatar
okay the range on ebay was $5 to $35 dollars is that right??? my mechanic told me that they were like $300 is the guy wacked or what??
Old Apr 4, 2003 | 08:26 AM
I've seen really good ones go for $65 bucks, but normally they are between $20 and $40 bucks.
Your mechanic is thinking of a Spring Compressor STAND. It is a spring comressor that is free standing. They are nice, but only if you are going to be doing a TON of spring/strut changes.
Just the "standard" cheap bolt style spring compressors will do the trick for occassional/shadetree mechanic use.
Old Apr 4, 2003 | 09:04 AM
2k Elantra's Avatar
Like Random said the $300 compressors are usually free standing or wall mount units. The smaller ones that you see for around a $100 are usually a clamp type set up which hooks to the top and bottom of the spring,then you tighten a bolt which compresses the spring. As easy as it sounds you have to be VERY carefull, if it is not compressing the spring evenly it may pop out of the compressor.
I'm not trying to scare you away from this,I'm just letting you know so you take precautions and you don't get hurt.
Old Apr 4, 2003 | 10:50 AM
JAWS 021's Avatar
ive never had a spring pop out on me... so as long as your careful you should be alright
Old Apr 4, 2003 | 01:11 PM
BoOm's Avatar
sears has a craftsman one for about 40 or so dollars. standard double bolt type. not too bad.
Old Apr 4, 2003 | 05:43 PM
MaierApril's Avatar
$300? I dont think you need one this good
Check your local Pep Boys or auto store
Old Apr 4, 2003 | 10:23 PM
ONLY1DB's Avatar
yeah i dont want to pay somebody for something i can do myself for hte cost of the compressor...ya heard.....thanks guys!
Old Apr 7, 2003 | 12:37 PM
Russ's Avatar
WHATEVER YOU DO just don't stand above the strut with it pointing at you when you compress the spring onto it!!! I have heard of people have the spring pop off the strut, hit them square in the chest, and die from it OR get seriously injured if they're lucky. That's all I have to add to this topic.
Old Apr 7, 2003 | 08:19 PM
I've heard those same tales. I think they fall under the catagory of "urban legend". Don't get me wrong, you can get HURT if the top of the strut comes off with the spring unrestrained, or if the spring compressor slips off, it will go flying. However I seriously doubt anyone has "died" as a result of one of these mishaps.
Moral of the story, just be careful out there folks! wink
