Loose E-brake
Old Aug 22, 2007 | 01:57 PM
kwin's Avatar
My E-brake is really loose. I was wonder what the easiest way to tighten it was. Also, is it possible that my rear calipers have seized?
Thanks, Kwin
Old Aug 22, 2007 | 02:15 PM
rallyman's Avatar
One or both of your parking brake cables may be seized or broken. If there is a lot of 'play' in the brake handle when you pull it up that is likely the problem.
You could check whether the rear brakes are seized by jacking up the rear of the car and seeing if the wheels will spin freely (with the parking brake off, of course).
Will the parking brake hold the car if parked on a slope?
Old Aug 22, 2007 | 03:13 PM
kwin's Avatar
Thanks for the help. No the parking break wont hold on a slope it has to be in 1st gear.
Old Aug 22, 2007 | 03:51 PM
Yep... you need to adjust your parking brake. there's a nut attached to the bar that ballances your two calipers. You can find it inside the center console under the lid, in the secret hidden compartment at the bottom.... You know, it's under the condoms, stick of gum, change and extra cigarette lighter..
Just twist that until you have 1 click of free play.
