I'm Going To Cut The Springs. Cutting Coil Springs.
Old Aug 4, 2013 | 07:33 AM
  #51
2000J25SP's Avatar
Vehicle: 2000 Hyundai Elantra GLS
I had the same issue as Stocker, the nose of my car was much higher than the rear. It looked like the car was going up hill all the time.
So I cut exactly 1 coil from the front springs. It still sits higher in the front but it's less noticeable now.
Before:
After:
Old Aug 4, 2013 | 07:43 AM
  #52
wheel_of_steel's Avatar
Old Aug 4, 2013 | 01:14 PM
  #53
If it's a value-add to the thread, revive away!
If you didn't, now is the time to go back and dress the end of the spring so it does not chew through the spring perch, but otherwise good job and thanks for the before/after pictures.
Old Aug 4, 2013 | 01:30 PM
  #54
2000J25SP's Avatar
I rounded out the cut ends with a grinder, if that's what you mean by "dress"
