Hawk or EBC greenstuff
Old Dec 16, 2004 | 01:12 PM
Default Re: Removing dashboard
exactly how it sounds
lookin on opinions on which is better
ive been using hawk but its time for a change
both cost about the same
any thoughts?
Old Dec 16, 2004 | 01:33 PM
UltraTibby's Avatar
Default Re: racing seat harness
You ever think about using PRB/Axxis pads? I;ve had the Ultimate ones on the front and Metal Masters on the rear since a little after I purchased the car and they are pretty nice. The only problem I have with them is the front pads make a good amount of dust. I dont have D/S rotors so that may make a difference.
Old Dec 16, 2004 | 04:15 PM
supercow's Avatar
Default Re: Avatars, Avatars, Avatars!!!***UPDATED 56K WARNING***
I've got hawk on the rear and greenstuff on the front. one thing is for sure the front make alot of dust. but they stop great!! so it's really a trade off. I would recommend them though.
edit: oh btw, last time I check ebc only makes front brakes for us.
Old Dec 16, 2004 | 04:27 PM
Default Re: Who misses hockey
I have EBC on the front right now.. and I have been unhappy about them because of the way they did not quite fit the caliper... I just got UPSed in front and rear hawk pads.... unfortunatly, I will not see a change in braking.. I am downgrading my tyres for the winter back to the 14 inch steel stockers.
Old Dec 16, 2004 | 05:22 PM
supercow's Avatar
Default Re: ultimate turbo set up
QUOTE (Mad-Machine)
what do you mean didn't fit the caliper?? only those two tabs on each end are important to hold it in place (well besides the rotor and the piston) and mine took a little bit of force to get in there... if they were larger, well then they wouldn't have fit. did you get the wrong part??
Old Dec 16, 2004 | 08:23 PM
Default Re: North East Meet DECEMBER 19TH
that I do not know... I had to remove the shim to get it to fit over the rotor... and even then it dragged enough at first to warp the rotor and kill the bearing.. but only on the passenger side. The driver's side was tight too, but not that tight.
Old Dec 16, 2004 | 08:50 PM
Zman's Avatar
Default Re: ARK SPEED RACING Discussion/Concerns
What you mention seems to be related more to instalation than the pads itself... maybe the piston needed to be compressed before putting the pads back in place... have you tried to drain/purge your brake fluid?
I had a problem with my rear brake sticking heavy, but it was a rusted piston, it was with OEM rear pads.
Right now I'm with my second set of EBC's and I am very happy with their braking performance. O btw they DO warp rotors, but I think OEM rotors warp with anything else than OEM pads, first set of EBC I used woth OEM rotors, this second set I am using with brand new Rotora slotted rotors.
Old Dec 17, 2004 | 01:21 PM
skierd's Avatar
Vehicle: 1997 accent L
Default Re: Engine Splutters.. need help
The Axxis Ultimates should dust less than the Hawks (understatement), but their dust is like superglue or something. I hate cleaning it off of my wheels. Good all around pads though imo.
Old Dec 17, 2004 | 02:35 PM
Default Re: RDTiburon Decals!
yeah, i like my axxis.
metalmasters. they're great.
Old Dec 17, 2004 | 02:41 PM
Default Re: Best Cheap OEM Mod Yet... *Teaser*
how hard are the axxis ultimates on rotors?
ugh i jus found out i need new ones
time for slotted instead of drilled and slotted
but i am hearin good things of the axxis pads and there like 30 cheaper than the hawks
