Vendor's Booth: General
ecu with maf to map conversion
Old Apr 17, 2003 | 08:00 AM
kane moser's Avatar
Default ecu with maf to map conversion
Any idea when it will be available? Is this a DIY install, or will i need to hire my local speed shop? Also i have a custom turbo kit (dsm ported 14b)not the cnk one, will i need to dyno test it after the ecu install or not?
Old Apr 17, 2003 | 07:57 PM
CNK Performance's Avatar
That conversion I am working on getting done, so far the CNK ECU solution will work with MAF in it's place BUT also with it's own MAP sensor aswell. So in essence you will be using MAP and MAF until the MAF runs out of range, then the MAP will continue fueling the engine.
Technically this is a conversion, but with the MAF stillin place.
Tuning will have to be done as the ECU is supplied with tuning done only for the CNK turbo kit.
Old Apr 18, 2003 | 01:37 AM
kane moser's Avatar
great chris. I was wondering, how difficult will it be to tune via a laptop. I`m no computer scientist, but i can get around. Will i be able to tune it myself?
Old Apr 18, 2003 | 02:19 AM
Kane -
I have started a new post about tuning an engine....check it out - it will answer your questions and more.
