Vendor's Booth: General
Discontinued injectors
Old Feb 14, 2003 | 03:54 PM
CNK Performance's Avatar
Default Discontinued injectors
Hi all,
I will not longer be able to supply you with the 550 Lucas injectors, these have been discontinued and are no longer available to me in South Africa.
I have decided to exclude these from the kit and include the ECU in it's place with tuned map for the turbo kit.
Old Feb 14, 2003 | 06:02 PM
lantraluvr's Avatar
Vehicle: 1999 Elantra
So what should we use instead of these injectors?
Old Feb 14, 2003 | 06:38 PM
MaierApril's Avatar
RC Engineering has 440cc injectors, that you can buy for a decent, fair price.
Look them up.
Old Feb 14, 2003 | 06:52 PM
lantraluvr's Avatar
Maybe I should just get better injectors for an Eclipse. Besides, there's that CNK ECU, right?
Old Feb 15, 2003 | 06:22 PM
Remember that the tuning on the ECU I now include in the injectors place are done for the 550cc injetcors.... So if you use 440cc injectors you will run slightly lean...... I suggest buying 550cc injectors from RC, for two reasons,
1) So that the tuned map will work 100% perfectly, and no tuning will be needed after installation
2) You are able to up the boost safely at a later stage for much more power, without worrying about maxing out the injectors and blowing your engine.
