The Tibby Its Done... 2 Years In The Making..
Old Apr 3, 2007 | 06:26 AM
  #61
Mad_john's Avatar
well sort of an up date.. i have gotton the block bored and honed out preping the head now. the 2x 255 walboro pumps i got rid of in lue of the fact they can do what i want them to do and mounting them in the tank will be a pain in the ass i went with the Bosh 044 2 each
and got an orc CF twinplate clutch i should be done in about 3 months then its time to check the ##
and i will be running 2 of these... they just got here today
..... well will have our day peps
Old Apr 3, 2007 | 07:42 AM
  #62
Alex01tib's Avatar
damn you and your push style clutch lol
looks great mang
Old Oct 19, 2007 | 11:19 AM
  #63
Mad_john's Avatar
so for the past year at Redsuns "where i have worked and learned this tunning shit" and multi trips to japan to HKS and Top secret. to learn the the skills need to map and rebuild/tune engines from The rew13b to the Rb26.. and putting in long day and nights 9 in the morning to 10 at night Mon~sat and some times staying at the shop for days on end.. I have also learned how to weld "Better" mainly the GTAW that is all we use here.. and it seems i am getting closer to what i want and have the car the way i want it. there has been so much sweat,blood and tears and the 2~3 degree burns that i have gotten from this car.. i have put allot of thought in to it as well..not to mention the countless fights with my woman and my best friend "co owner of Redsuns" but i thought i would share what i got so far..the only things i have to do now is make the manifold the exhaust witch will be a 3"down pipe to 4" all the way back. and the fuel system witch i will run 2 bosh 044 with one on a toggle switch so one for low boost 1.Bar and 2 for high boost 2.6 bar. and cc inj and 3" ALU I/C piping.
I will also install a fire suppression system "halon". and finial the wiring witch will include a plx-550,avc-r. and 3 other gage's oil.fuel.temps. i am looking at being done by Nov.. but i am so pick about this build ahhhhhhhh.... the engine will be done by Monday and ready to put in. i ordered a OS plate the same as the one i posted about not to long ago. i sold the carbon ORC clutch for that..so i must wait about 2 weeks for it to come from japan. and in that time i will do wiring and getting the other things ready
here is the engine
crower Ti rods
balanced crank
rod/mains clearance's have been re done
bored/honed 1.5mmOS
ARP head/crank bolts
THANKS TO JONGTR.....
Head work
272 int/ext cams 9.7mm lift
duel springs
customs Ti retainers
new chain/valve seals/guides
Valves int/ext ports
Valve have been reshaped and balanced by me by hand and that to almost 7 days. 2 1/2 hours per valve. .
int valves weight 40.25 grams
ext valves weight 41.25 grams
i mess up about 8 of them when i was doing this
new IC
Old IC
to give you an ideal of the size to compair them, the new one is 4"thick
body and frame work i did was stitch weld the whole car and installed a 6 point cadge though tonight when i was taking pics i might go to a 10 point.
i also removed all the old ass sound deadened and installed new dyno-mat. as for the A-pilers i will replace the plastic covering as well as the lower kick panel covers and door stills.. i want the inside as clean and as new looking as possible. I am trying to maintain the sleeper look.
back shot
Old Oct 19, 2007 | 11:33 AM
  #64
WOW! amazing what youve done. Im going to be going big boost here in a few months probably. Only thing im confused about is the setup of the inline pumps. You still have single rail too, correct?
Old Oct 19, 2007 | 12:01 PM
  #65
Kantizuni's Avatar
Vehicle: 2000 Turbulence
John, you're my hero.
Old Oct 19, 2007 | 01:35 PM
  #66
rollwitstyle's Avatar
lookin good man cant wait to see this done and dyno'd good luck
Old Oct 19, 2007 | 07:24 PM
  #67
peter_2150's Avatar
Looking Great. When you get done with it you need to post ever thing you did and partlist so we can all copy lol.
Old Oct 19, 2007 | 07:56 PM
  #68
hesus!!! ok it's official, you have the best tiburon i've ever seen in the world, ever.
hot damn... you've GOT to give us some photos of the exterior too. That car is AMAZING Mj. I won't comment, but I will say just one thing:
It's good that you like your Tiburon and not some other who knows what car. You just wait what your girl has to say when the car is DONE for good. I don't think it's COTM, it's COTC: Car of the Century.
Old Oct 20, 2007 | 03:32 AM
  #69
Mad_john's Avatar
Thanks guys that means alot to me Really... I have not torqued the head down yet i frogot to CC the compression chambers to obtain total balance.. so i will take some more pics to show you guys what to do.. I will admit there was times when i just said f*** it and called a toe truck to shit can that heap but i woint fail in my task this will be the best i can do and i will do it with my own hands...
Old Oct 20, 2007 | 07:33 PM
  #70
hell yea man you just keep steping up the dream. hopefully i can build just a fraction of what your car is. hail.gif
