Another Thing.. Dual Stage Boost Controller
Old Jun 25, 2005 | 02:36 PM
mb1604's Avatar
nice, thats sweet. loose one race, change the setting and shock them!
how much did that cost you?
Old Jun 25, 2005 | 02:40 PM
Agarwal's Avatar
I'm getting that one too (the HP one, don't know if you got that one); I'll probably be wiring it so the high boost setting is on whenever it reaches a pre-set RPM (throug the SMT6), or maybe with a switch on the 2nd or 3rd gear. It's pretty useless to boost in 1st gear; all you do is burn tires. Having it by RPM is nice too; if you just want to cruise, you just drive normally, and set your wastegate at a VERY low boost (like 2-4 if possible). Whenever you want the power, you just floor it.
Old Jun 25, 2005 | 04:01 PM
dont have it by rpm then. have it turn on by WOT, or something close.
Old Jun 25, 2005 | 08:41 PM
UltraTibby's Avatar
Why did you opt for a manual controller over an electronic? Just personal preference?
Old Jun 25, 2005 | 08:42 PM
I would wire it with a magnetic switch so you have low boost in first.. like was said, lots of boost in that gear just equals more wheelspin. If it was me, I might even wire it for low boost in first and second..
Old Jun 26, 2005 | 01:01 AM
Cuda-Turbo's Avatar
I have really like my Apexi AVC-R boost contoller, you can have gear specific boost control and you can switch boost settings with a few button pushes.
Old Jun 26, 2005 | 07:42 PM
1997tibby's Avatar
Vehicle: 02 Accent
about a month ago i was searching for wastegate controlers to hook up to full standalone systems and i saw a stepper motor controlled wastegate. You can set any boost level through the laptop from like 5-30psi....i dont really know too much about the stepper motor controlled wastegates...anyone ever seen one, know of any good ones, have a link to one?
