$30 Ebay Cold Air Intake
I had recently bought a $30 knock-off AEM cold air intake off of ebay.
The eBay username is chromeintakes
here is the listing i bought it from
here are links to the pics i took of the system installed on my tib
Picture 1
Picture 2
Picture 3
Picture 4
Picture 5
Picture 6
Picture 7
Sorry about the links, but I have yet to figure out how to post images directly using Google picasa albums to the board.
The sound is pretty good from the CAI, and not that there is a noticeable hp increase, but the engine definitely responds faster when you touch the accelerator. As for fuel economy, I have to use up a whole tank or two of fuel and see if there is a repeatable increase in mpg. I will say that it seems unofficially that the tib is getting 1-2mpg better then before.
Let me know what you think of this set-up and if you have any questions.
Picture 1
Picture 2
Picture 3
Picture 4
Picture 5
Picture 6
Picture 7
pretty nice.. but not the AEM knockoff.. you shoulda got the AEM knockoff, its like 10$ more but a MUCH better intake..
i love those style filters.. i have one of those filters on my turbo intake..
That's not mounted anywhere. I made a mount for an earlier CAI I had out of aluminum stock from home depot and some pipe clamps. Just find 2 bolts it can connect to (top of tranny stock airbox mount, and fender airbox mount) then bend the metal in a vice to run along the pipe and meet those two bolts.
Vehicle: 97 Tiburon
<div class='quotetop'>QUOTE (IronFox @ Jan 13 2008, 06:21 PM) <{POST_SNAPBACK}></div><div class='quotemain'>How do you know which one is the knock off? They all look the same to me!</div>
AEM & clones get mounted in wheel well. Injen & clones are under the battery tray
DTN - it's held in place from slopping all around right now by a black cable tie around the piping and the clutch master cylinder till I can get to home depot this upcoming weekend and fabricate a correct bracket for it. Thanks for the idea though, i realized that i should have it more securely mounted after I loosened all the connections on the piping this morning to fit it better for the pics and general placement. So when i go to home depot i'll fabricate a bracket and also get the water separator for the home made catch can.
Lilo Shark - It's an injen knockoff? I thought it was an AEM. Sparticus cleared that up for me in his post. Thanks Sparticus. Maybe I should get a vinyl label made to put on the CAI that says 1/2 injen or something to that extent. I'd sport it since I don't do shows or anything.
