Who Here Has Gone S/c?
I was just curious to see who here went s/c instead of turbo or N/A and what kits are you using w/ what mods? I'm not looking for extreme gains, and I'm not looking into turbo so I thought s/c my Tiburon would be the way to go.;D
Vehicle: 97 Tib
the only S/C available is somewhere around the $~3K range, and it won't even get you over 200WHP.
a turbo set up is also in the $3k range, you can keep it low boosted on stock internals and get higher numbers than both S/C and N/A. T/C is the same price, better numbers and WAY more expandability if you turn into an addict.. your call.
No room for a large supercharger, and a tight fit for any type of air to air or air to water intercooler means power is limited. You could run a turbo to the same amount of power for half the price, and have all the plusses of a supercharger (power off the line, etc.)
Vehicle: 97 Tib
imo, this ought to just be locked. this topic has been discussed over and over, if you search around, even dynos of the most ELABORATE s/c setup on a tib can be found (Xorro's 199WHP water cooled s/c UK tib).
supercharger is not cost-effective and is beat out by a turbo in every aspect, including cost.
