the turbo LC project moves
Old Jun 9, 2002 | 03:32 PM
skierd's Avatar
Vehicle: 1997 accent L
Default the turbo LC project moves
My new turbo:
"This turbocharger has been upgraded to Hi-pressure brass fittings. the water inlet and outlet now uses 3/8" hoses. the oil inlet and outlet also have been upgraded. the oil inlet has been upgraded to 1/4"NPT fittings and the outlet has been uprgraded to 1/8"NPT fittings. This turbo also comes with a 90 degree elbow that makes installing the charge pipes much easier. When charged with oil there is no play in the shaft what so ever. The compressor housing is fully polished and the rest of the turbo has been painted with a Hi-temperature paint that has been baked and cured. Also included in this auction is a gasket for the 90 degree elbow and a steel weldable oil drain bung which is to be welded to the oil pan for proper oil drainage. The oil drain bung accepts a 1/4"NPT fitting."
Got it off ebay, won the auction at the very very last second. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=1834019197
Old Jun 9, 2002 | 04:29 PM
morningla's Avatar
Vehicle: na
put it in man, put it on
give us some specs/pic when done
Old Jun 9, 2002 | 06:40 PM
for an IHI turbo, that is a sweet price. eek!
Old Jun 9, 2002 | 07:02 PM
9o7TiB7o9's Avatar
That is a BEAUTIFUL piece of machinery! So hey, how much do you estimate the total cost for the rest of the required parts?
Old Jun 10, 2002 | 02:36 AM
skierd's Avatar
I'm going to say $2500, give or take a few hundred (probably give sad.gif ).
Donations accepted through paypal at skierd007@hotmail.com.
Old Jun 10, 2002 | 05:00 AM
Red's Avatar
Red
Looks like an IHI RHB5, guessing a 311-spec because the compressor side isn't as big as my 393-spec was. That would mean it came off a 1.8L turbo Subaru.
Saying I've guessed the above correctly, that turbo is good for around 190-200whp. Not a bad place to start, just don't overboost the hell out of it. It would probably be most comfortable (ie within it's efficiency range) around 170whp give or take.
If that turbo is indeed the RHB5 393-spec off one of the 2.2L Imprezas or something, then it's good for about 220-230WHP at peak; efficiency range is more around the 190-200whp range.
I bought my 393-spec for $150, cleaned it up and then re-sold it again for the same money smile.gif What made me get rid of it was the wierd-assed 5-bolt pattern on the exhaust side. That is a BITCH to make a custom downpipe for...
P.S. I may still have the flowmaps for both of those turbos here at the office somewhere. I'll check around and see if I can find it...
Old Jun 11, 2002 | 03:48 PM
skierd's Avatar
ever find those maps red? I know that i wouldnt be the only one interested...
might as well tell the rest of the list of parts i'm planning on while i'm at it.
*Probe, Supra, or DSM intercooler (ebay or junkyard)
*OEM Supra BOV (thanks to shadohh smile.gif )
*OEM tiburon injectors (thanks to shadohh again smile.gif , 245cc/min)
*fuel rail and return line from a 2000+ accent equipted with the 1.5L SOHC (for the conversion to return system)
*Vortech SFMU
*Walbro 255Lph fuel pump
*Autometer A/F ratio, Boost, and EGT guages
*Denso Iridium Plugs
*KORE Stage 3 clutch
*Manifold
1)1.6L DOHC accent manifold with the cat hacked off and a mounting flange welded on in its place, possibly ported
or
2)custom logs style manifold
*downpipe and o2 housing for whichever subaru this turbo came from
*custom 2.5or 3" exhaust, depending on downpipe
Sound right for a 7psi (what the stock wastegate is set at) setup?
Old Jun 12, 2002 | 02:08 AM
twistedH's Avatar
i made my donation to your paypal account, skierd.
it was just too good to pass up.
Old Jun 12, 2002 | 03:13 AM
skierd's Avatar
lol, thanks for your contribution.
And yes, i've already checked my mail, lol.
Old Jun 15, 2002 | 03:37 AM
skierd's Avatar
Checked my bank account today... It seems i need to sell the turbo now, cause i wont have enough money for June car payment or food next month if I dont.
I'll be relisting the item on ebay either tonight or tomorrow. Bidding starts at $200. sad.gif sad.gif frown
