Suicidal Turbos
Old Feb 9, 2011 | 02:54 PM
  #21
tanc's Avatar
Vehicle: 1997 Tiburon
^^^ I HGHLY do not recommend that. That's the easy/cheap way to fix your problem that might cause you bigger problems in the long run especially during an aggressive turn/slalom.
Old Feb 9, 2011 | 03:39 PM
  #22
turbosocks's Avatar
i agree with tanc.. NEVER use less oil than recommended, just do things right the first time..
Old Feb 9, 2011 | 07:43 PM
  #23
slow 2K2GT's Avatar
Vehicle: 2003 Hyundai Tiburon i4
IMO the optimal oil return line goes into the block but if you ever decide to return to NA than you need to find a plug and put it in with some thread locker.
Old Feb 10, 2011 | 04:15 PM
  #24
steelcoffinx3's Avatar
Vehicle: 99 accent
Anyone that only goes to shops for oil changes is running a little down on oil after a few thousand miles (like a pint), oh sh*t it threw a rod!... uhh no, your still getting oil pressure just don't go road racing on semi-slicks or better put new hole where it should be.
Old Feb 11, 2011 | 11:40 AM
  #25
Vehicle: 99 accent
uhh ok, when's last time your car was down a pint of oil from 100% full capacity (the dipstick would read pretty much full)? did it blow up? no, it's still in the safe range.
Old Feb 11, 2011 | 12:53 PM
  #26
tanc's Avatar
I've never taken out a loan to build my car, I've done it over 5 years working hard. Your's is faster than when you got it, that's progress but please don't pass on advice that sure it's fine driving your NA accent with 1 pint of oil under full. For you it's fine, sh*t my dd probably has 2 pints under full but I'd never drive my 420whp high boost car knowing I'm under in oil. That's flipping a coin.
Old Feb 11, 2011 | 01:49 PM
  #27
TibbyTurbo's Avatar
Vehicle: 1998/Hyundai/Tiburon FX Turbo
Hey Guys I found a video on youtube with exact same sound I hear with my car, its the sound you here at 1:08 of this vid click Here
Old Feb 11, 2011 | 02:02 PM
  #28
Vehicle: 99 accent
Sounds like the compressor blades are rubbing against the housing take you turbo out NOW and you might still be able to rebuild it.
Old Feb 11, 2011 | 02:16 PM
  #29
TibbyTurbo's Avatar
I was hearing that sounds for awhile then when I dropped off the car to the shop last week they were shock that my compressor wheel is so beat up the compressor nut came off and beat up the compressor wheel. I have read this thread from another forum seems like he have exactly same problem as me: Click Here.
Old Feb 11, 2011 | 02:43 PM
  #30
Vehicle: 99 accent
Then the turbo is probably fubared, tee the oil feed from the pressure sender and make your getting enough oil pressure.
