Replacement Turbo
Old Aug 3, 2005 | 08:39 PM
boostedtib's Avatar
Vehicle: 1998 hyundai tiburon fx
I am currently running a t3/t4, It started leaking through the seals and out the exhaust real bad and realistically, I am looking to run no more than 300whp, if so. I know that with this turbo, it's good for about 450, 500whp. Obviously i'm not looking to run anything near that. So i'm looking for a turbo with a little bit quicker spool time and will get me to 300. What do you guys think of the t3 all around. Internaly wasted to avoid the extra piece of pipe for the extarnal waste gate and clear up some room in the engine bay. Thanks guys.
Old Aug 3, 2005 | 08:42 PM
well i heard that a t3 super 60 spools pretty quickly ive never been in a turboed tib to tell you exactly how it feels though
maybe a t28?
Old Aug 3, 2005 | 08:44 PM
what about a dsm 16g? 14b? t25 even?
Old Aug 3, 2005 | 09:08 PM
boostedtib's Avatar
I will see what kind of prices I can get on either one and I will let you know. I know about the t3 60 trim, the 16g i'd have to look into it. Thanks for the advice guys. keep'um coming. Post your thoughts and suggestions, I appreciate your input. By the way wich turbo came with your kit?^^^^
Old Aug 3, 2005 | 09:27 PM
Disco Potato my mang, all there is.
Old Aug 3, 2005 | 11:59 PM
Agarwal's Avatar
All dsm turbos uses a different exhaust flange than a T3, making them unpractical to use with most available manifolds.
You have LOT'S of choice in "T3-flanged" turbos; a T3 .48/.60 turbo will make 300hp and spools pretty quick. That's what I'm using, and I should be at full boost at around 3400-4000rpm.
A "big" T28 is almost identical to a .48/.60 turbo, but they use a T25 exhaust flange.
Old Aug 4, 2005 | 12:04 AM
OdessitPashka's Avatar
QUOTE (REDZMAN @ Aug 3 2005, 10:27 PM)
I second that! Get a GT28 by garret! Will spool about 500-1000rpms quicker and will hold enough power smile.gif
Old Aug 4, 2005 | 01:01 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
what about ball bearing turbos? I think it's GTR Garrett series.
Old Aug 4, 2005 | 01:02 AM
Agarwal's Avatar
^a GT28 turbo would be a ball-bearing turbo. "GTXX" denotes a BB turbo.
