Problem With Turbo Adjustment. Help!
Well I'm test fitting my manifold and dp and when putting it in found that the compressor was set to point straight ahead and of course won't fit so I decide I'll just do the adjustment and point it straight down... it won't do it!! all i can get is straight forward and straight back due to the acuator getting in the way.
I'm thinking that someone said to just bend the rod going to the acuator but I figured I'd get some advice first.
btw, I've got:
-t3 super 60
-speedfactor log mani
-speedfactor dp
thanks in advance
supercow
btw, I've got:
-t3 super 60
-speedfactor dp
thanks in advance
supercow
ah ha! it was random who said to bend it! - http://www.rdtiburon.com/index.php?s...c=6688&hl=bend
so what do you think...
btw, op, i have taken those bolts off. there are 6 of them. 4 that are on two clips and 2 on the acuator. the problem is that when i move the compressor outlet to point straight down then i can't reattach the acuator because it goes from the very bottom of the turbo to the bottom of the compressor where the outlet now is and the acuator needs to be where the outlet is... I think the cleanest way would be some custom bracket.
dang i figured straight down was the default direction. is this a common problem?
I think i know what it is... tim's log manifold is at an angle and most equal length manifolds are going to be level. It was originally pointing straight forward which would almost be straight down on a egual length mani. I guess I'm going to need to talk to him about it.
