Piston choices
Old May 29, 2014 | 11:15 PM
XGODZX's Avatar
Vehicle: 1999 Elantra GLS Sportswagon
Originally Posted by Stocker
Thanks m8
Old May 31, 2014 | 07:17 PM
Regit's Avatar
Vehicle: 2000 tib
since our engines don't have wrist pin oilers ,I had my pauters rifle drilled.
Old Jun 2, 2014 | 04:56 PM
alice6's Avatar
those rods are so perty! did they charge extra for the rifle drilling?
Old Jun 4, 2014 | 12:50 AM
99x3beta's Avatar
Vehicle: 99/ Hyundai /accent
So what would be the cheapest piston and rod set up out there?
I like the stock bore (82mm) stock compression piston that he was talking about.
But there has to be limits on boost. Meaning boosting at 10.1 compression that's kinda high to be raising boost. But sure I could make 300+ easy with a good piston and rod set up
Has anyone used them? What would be a safe psi on those?
Old Jun 4, 2014 | 09:37 AM
psi is relative and generic
20 psi on a t28 isnt the same as 20psi on a t4
of all the places to look to cheap out, the internals of the motor arent the way to go
Old Jun 4, 2014 | 08:28 PM
The cheapest pistons are the ones you already have. They are good to 300-ish horsepower. Unless you are familiar with super-high power in a FWD car, I'd say shoot for 270-320HP on stock internals and see if it's still fun (to you) to drive.
Old Jun 4, 2014 | 09:12 PM
99x3beta's Avatar
Stocker sounds like a good plan. Thanks for the advice doesn't sound to bad for my first turbo build I guess. And I will be running a t4.
Do you think there's anyone that can guide me in the right path. Tuning wise?
Yes base map but trying to take it up to 275hp range?
Old Jun 5, 2014 | 10:12 PM
Spend a couple of *months* reading threads here. Read Maximum Boost by Corky Bell. Then read some more here, THEN start asking the few, good questions you don't already have answers for by then.
Old Jun 6, 2014 | 03:40 PM
99x3beta's Avatar
will do thank you
Old Jun 19, 2014 | 03:42 PM
JonGTR's Avatar
Do a simple turbo kit first, then see if you want to tackle the internals afterwards. Doing both is way too much for a beginner. You'll end up with too much work and too many headaches in a row, get discouraged, then scrap the project. Happens all the time.
