Oil Line Prob.
Hey i got a problem i got Speedfactors kit from someone and i am haveing problems with the oil line. The Black hose as the fitting where something will screw into it and does that go to the oil pan and the hose to the turbo. Here is a pic let me know.
I would ditch the barb hose crap and take the time to find a SS line with threads on both ends.
why not simply drill and tap the engine block itself instead of the oil pan?
factory clena look and no hose near the downpipe
Basically, you want the oil return line to be below the turbo, but above the oil level in the pan. That generally leaves the top of the pan.
It could be made nicer if you had time.. take the pan off, weld the bung in, and then ship the whole thing off to be powdercoated.
Guest
Posts: n/a
yah i was gonna make mine nicer, but i figured, for now i want to get the thing running and on the streets, for now im done making things pretty.. but i did pick up a business card for a powdercoating/ceramic coating place.. hmm what to do..
i think the spot for my line is a good spot, but we will see how everything reacts once i work out the bugs and get her runnin
with the "real" motoria manifold, ss autochrome manifold,champion,spintech you have enough space to put the oil return in the block
other manifolds you'll have to check
