Turbo And Safc2=no Good?
Old Aug 8, 2005 | 08:46 AM
planrforrobert's Avatar
In another post in this particular forum, I talked about buying and installing a turbo in my car. As the post went on, it got into what standalone/ems would be right for this set up. My initial idea was to by an SAFC2 and run that with the turbo, but was told that it would be fruitless and that I should get in on the impending GB for the PRS2 standalone. My only question is, what exactly is "no good" about running a SAFC2 on our cars? All I have heard anyone say is that they are no good, and anyone running one will want to switch to a standalone after a short time, but they offer no explaination as to why. $600-$700 for a full standalone is something that would crush my wallet...
Old Aug 8, 2005 | 09:00 AM
JonGTR's Avatar
1. The SAFC only cuts the MAF signal to tune the injectors. This inturn fuks up your timing because the ECU thinks your running half or twice the air you actually are. Depends on the injectors you have. There's more to it, but.............
2. The stock ECU does WTF it wants until 4krpms, no matter what you plug into the SAFC. And what it wants to do is lean the hell out of the motor, basically destroying it. It took mine 2 years of running lean before it burned the rings, but still..........
During WOT, the SAFC runs ok. You'll only be lean for that first time you floor it, then it'll start dumping fuel and take off through all the gears. But for daily driving, it sucks. Kaboom!
3. The SAFC will only cut 50% of whatever injectors you have. So 470's are pretty much the biggest you can run. I have these and the on/off throttle sucks and is extremely jerky.
4. SAFC + MSD will run you $650 new and does a halfassed job. The PRS can controll any size injectors, tune any way you want, and runs $675 for the regular price. The GB will probably be WAY less.
Old Aug 8, 2005 | 09:06 AM
Damn, that sucks. With a $600 or so price tag, that will be a huge setback in getting my car boosted.
Old Aug 8, 2005 | 09:14 AM
JonGTR's Avatar
Yea, you'll just need to get a GM MAP off ebay for like $40-50 which will allow you to throw away the MAF. fing02.gif
Old Aug 8, 2005 | 09:23 AM
To Jon and Import, I do not plan on runinng more than 8psi of boost, and do not want to over 200 whp. I just want something that will give me some extra performance, with out car becoming a beast to drive. And let me get this straight, if I do not plan on running loads of boost, and keep it around 200whp, I will be ok with the SAFC2?
Old Aug 8, 2005 | 09:32 AM
JonGTR's Avatar
I have no idea. I never planned for anything less than 200whp since to me, it's not quick enough and it'll get beat by lightly modded civic/hatches.
I don't see it working for 8psi since I know it won't for 10.
Old Aug 8, 2005 | 09:23 PM
TiburonWao's Avatar
Don't think that you don't want more boost over 7PSI.... BOOST is highly addictive....
Old Aug 8, 2005 | 10:27 PM
At the risk of being laughed off the site, I have one final noob question. What would be the outcome if I did not install neither a SAFC2 or the PRS2? This seems to be the only "option" I have not asked about tongue.gif
Old Aug 8, 2005 | 11:55 PM
iQfOreVa's Avatar
Vehicle: 2012 Mustang GT
BOOM.
