Oil Line Fittings
Old Feb 7, 2006 | 08:49 PM
Denisst99's Avatar
if it can help you...
i take my oil pressure form the front of the block wit ha "T" fitting, got 8" of #4 braided steel hose,#4 banjo fitting then the turbo
quite short, far away from the manifold and far away from the wastegate actuator and some slack so i can install it without major trouble,in some case i even use a oil restrictor right before the turbo to get less oil flow/pressure
