Oil In Compressor Housing
Old Nov 22, 2005 | 09:32 AM
Agarwal's Avatar
^Pics of where to tap the block.
Old Nov 22, 2005 | 09:52 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
QUOTE (fastuning @ Nov 22 2005, 05:38 PM)
** MOD EDIT: quote removed
but.....where? in what part of the block? can someone put photos of where will be the return oil line in the block?
Fastuning, please do not quote the post right above yours. Use ADD REPLY button at the bottom of the screen.
Old Nov 26, 2005 | 11:31 AM
12SecRD's Avatar
So most of you think the return line is to low in the pan?
Old Nov 26, 2005 | 03:45 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
No I don't think that. If you put it in the spot Agarwal is suggesting you'll have even more problems.
Because of the turbo in your application being as low as it is, you have to use the pan. I suggest reworking your return line as it does look liek there is a slight upturn in the line causing the flow of oil to slow and "back-up" in the line and forcing it into the compressor housing.
Your only option other than reworking the line is setting up a pump to create pressure, I sure you know but there is no oil pressure after it leaves the bearing housing. It's all mother nature.
Old Nov 28, 2005 | 06:23 AM
12SecRD's Avatar
Ok so I removed the return line and cut it off about 1/2" to help the line be more straight then coming in on a curve.
I am still un easy about the return line though.you can notice in the pics above with the fitting onto the pan its just a tad bit higher then the line coming in. I have feeling that this is still no good.
I would just move the bung up about 1/4" more but that will only make the slope of the line and the oil pan fitting incline worst.
Will this be ok? Is there enough pressure coming out of the return side to help move the oil into the pan?
Or the only other option I may have is to move the return to the pan to the right. I would have to drill a hole where I marked in white and have Tube,Pipe, welded on the outside and then clamp the return line on it. This would allow me to get nice slope of the turbo and then straight into the pan. The line would only be 4-5 inches maybe. Or is the location of the return into the pan no good? Also where the white is marked I would prolly have Bend it out to try and flatten it about to give some more space because its curvy over on that side of the pan
Here is a PIC of where the oil will be entering(White spot)
Oil PAN
MOD EDIT: pic url updated
Old Nov 28, 2005 | 07:31 AM
Dmitry's Avatar
this way I think return line fitting will be pointing down from the oil pan.
