Obx Adjustable Cam Gear Issues
Old Jul 26, 2009 | 11:00 AM
Sell it and pick up the Fidanza one, it's frigging beautiful.
The Fidanza one said 30Ft Lbs if I remember right.
http://www.streetperformance.com/m/cats/19...shaft-gear.html
Old Jul 27, 2009 | 10:36 PM
Denisst99's Avatar
i had a few incidents and headaches with the fidanza cam gears also...
Pascoile could write a book on it...
Old Jul 27, 2009 | 11:44 PM
it's a cam gear.
it's going to be lighter just in the difference in material. if it fits the belt/cam, is the correct diameter, and doesn't fall apart i can't see where all these problems are coming from.
Old Jul 28, 2009 | 02:58 AM
Tony Vendetta's Avatar
so final verdict is their anything wrong with the obx cam gear? because I was thinking on getting myself one, because I have read both good and bad results.....
Old Jul 28, 2009 | 05:32 AM
warp21's Avatar
Vehicle: 2000 Hyundai Accent
I'm pretty sure it's usable but I'm not going to use it. Once I install the cams I'll check them with the stock gear. If they're off I'll have the stock gears key-way relocated so that it matches up with the re-grinders recommendations.
Old Jul 28, 2009 | 12:39 PM
i don't understand why you would want to do that, but it is your prerogative. lighter, adjustable, no machining needed, and you already bought it.
Old Jul 29, 2009 | 10:13 PM
Denisst99's Avatar
the obx cam gear is about 1 1/2 teeth off compared to a stock gear (that is if you use the existing timing mark)
