Injectors
Old Oct 16, 2005 | 10:50 AM
t4turbotiburon's Avatar
any of the bosch style injectors will work, to answer your question of will the mustang ones work most likely yes they are a standard ford/gm style which is what we use. 440 will only be good fro around 350-400whp if thats what you are shooting for. If you do go with the emanag and you do happen to run out of fuel it is an easy add on for 2 additional injectors in front of the throttle body but i dont recomend it due to cyl to cyl diffrences in fuel flow. However teh greddy ultimate has the capability to alter cyl to cyl fuel flow IF you have a wideband on each cyl. So yes it can be done and yes it would be safe ONLY if tuned proporly by a professional. Again this needs to only be done if you are running slightly short on fuel and just need a little more to be safe say your running fine up to 5k and then it starts leaning out this is fine for that but if you run lean under all boost cases then you just need larger injectors.
Old Oct 17, 2005 | 02:16 PM
00tibby's Avatar
so for around 300 whp. 4 440ccs will work?
