HELP FUEL
Old Jan 22, 2012 | 07:51 PM
yellow01's Avatar
Vehicle: 01 tib t3t4
I recommend aem fic do not use safc I am not familiar with blox but if it just intercepts maf signal like safc it most likely will not work correctly. I am surprised your car is even driveable with 440's and no engine management. That fmu will work also but you will be limited in boost to about 10-12 psi max
Old Jan 24, 2012 | 10:01 AM
jcturbeau's Avatar
Vehicle: x3
FMU is a mechanical device, not an electronic device. it's like a secondary fuel pressure regulator.
i'm still beside myself that with no fuel tuning or adjustable fuel pressure regulator and stock MAP/MAF, you installed 440cc injectors and the car ran alright. what are you running for spark plugs? and at what gap?
Old Jan 24, 2012 | 10:47 PM
bmxer's Avatar
Vehicle: 2006 Kia Spectra5
I'm going to assume you have converted to a return type fuel system?
What is your idle A/F?
Cruise A/F?
Acceleration with no boost A/F?
