garrett or turbonetics?
I agree with turbosocks, there isnt a whole lot of experimenting to go on in regards to a turbo combo. A Garrett GT28 or .50 trim journal bearing will provide lots of power at a very reasonable price. Personally after having used a journal and ball bearing turbo I can say that the extra money spent on the BB is well worth it but its not rebuildable, however I havent heard of as many BB turbos bursting as I have journal bearing turbos.
Either company is going to make an excellent turbo which will do the same thing at the end of the day, but you should be able to get a hybrid turbo from any company for less that $700, also remember that if you want an internal wastegate it will most likely cost a little more.
60 trim
Precision T3 50 trim
Garrett T3 50 trim
60 trim
Garrett T3 50 trim
again, i still don't see this 'customization' difference. the place i get all my turbos from for my turbo kits that i sell, I can pick anything i want and have them do a custom build on it..
these are just SOME of the options i have for the garrett t3/t4e
Base Turbo:
Garrett or Schwitzer .50ar T04E Compressor Housing
57 trim T4 Compressor Wheel
Garrett T3 .48ar Turbine Housing
Stage I Turbine Wheel
Options:
Internal wastegate with 3 bolt or V-band flange or no integral WG
.60ar Schwitzer compressor housing
Water cooled bearing housing
Stage II or III turbine wheel
O-trim or P-trim turbine wheel
.36ar, .58ar, or .63ar Turbine housing
.82ar turbine housing
.70ar T04E compressor housing with anti surge inlet
60-1 compressor wheel
among other comp wheel options
only a few of the options will actually add to the initial turbo price ~30-40$ like the huge comp housing with anti surge or a .82 turbine housing.
what else more could you ask for in customizing? pick your wheels, housings , bearing housing (oil or oil/water) internal WG or not
Base Turbo:
Options:
Base Turbo:
Options:
Base Turbo:
Options:
