Do you need a performance clutch with a turbo or supercharger?
Vehicle: 2000 Tiburon
I was reading a post, and someone reccomended that if you get a turbo, you will need a performance clutch. Is this true? Any info on this I would appreciate.
Is it necessary to upgrade the clutch. I am definately interested in geting the brake upgrade. How much would a nice clutch cost. I don't need anything fancy, just something that will last with a supercharger. Also any idea how much it will cost to have a new clutch installed? Also can you physically notice a difference once a performance clutch is installed or not?
Depends on how much HP you plan on makin'. Not sure what the stock clutch can handle, but i doubt it is rated for a turbo application. I would bet with anything over 200hp you would burn it up in no time.
more grip=less slip and a good launch
yes, you will definately need a new clutch if planning on running any more than 4 or 5 PSI. kore motorsports sells their "stage 2" clutch for 299, the stage 3 (id recomend for turbo applications, and is what im going to run) sells for $389. their website is http://www.kore-motorsports.comkore-motorsports.com
id suggest just buying the ballistic racing kit tho, it includes everything you need from turbo, to ECU, clutch...etc. i wish i would have purchased it tongue.gif
The Kore clutch units are MUCH cheaper than the Clutchmasters units.
yes, you CAN tell the difference between a performance clutch and a stock unit. The performance units do NOT like to slip. If you want to 'slip' it into gear, you must power through the clutch (2500-3000 rpm), on the stock clutch, you can slip it in at idle...
A peformance clutch grips much faster, and harder than the stock unit.
I would reccomend a stage2 for the supercharger and a stage 3 for the turbocharger. A higher unit if you plan on "madd boost" like red, Onpol or myself.
