Discuss this pic :)
Old Mar 4, 2005 | 07:29 PM
You know what seeing this makes me think of?
1. Remove fuel tank.
2. Route turbo into old Fuel Tank area. Unexposed.
3. Go for a fuel cell.
Old Mar 4, 2005 | 07:32 PM
OdessitPashka's Avatar
QUOTE (REDZMAN)
Unless you are going to isolate all the hot piping, it would be PITA to have exhaust pipes inside of your car.
4. make the charge pipe look like a twin exhaust system
Old Mar 4, 2005 | 07:33 PM
QUOTE (OdessitPashka)
Who said anything about inside the car? Remove the FUEL tank. I'ts under the car.
Old Mar 4, 2005 | 07:34 PM
SloKDM's Avatar
or how about this...just forget a turbo setup and go with a supercharger for a domestic vehicle.
btw, RED please check you PMs
Old Mar 4, 2005 | 08:19 PM
redturbulance's Avatar
Vehicle: 2001 Hyundai tiburon
A guy in my CC has one of these on his Toyota Matrix. I live in Seattle(where it rains) and he has had no problems with it sucking up water. He has this weird K&N cover for the filter and he does just fine. He really doesn't have that much lag either. I will try and resize the pics and post them that i have
JD
Old Mar 5, 2005 | 12:18 AM
phorq's Avatar
I saw this on 2 guy garage too... they explained that the lag is negated because of the displacement of the air that is already in the piping. I also thought it was weird that the filter was placed behind the wheel of a rear-wheeled car that could toss mud and slush onto it.
Old Mar 5, 2005 | 12:32 AM
Arctic Seraph's Avatar
*INFLAMITORY COMMENT REMOVED*
Second...I've seen that done to many cars. There's a Porsche 911 with a TT setup like that.
Also...I dislike this setup b/c not only is your turbo prone to damage from rocks and ish...(not a good street setup), but you ruin the underbody aerodynamics. 'course, most people just use that setup for dragging, so there are no real practical uses to this setup.
Old Mar 5, 2005 | 10:32 AM
Agarwal's Avatar
You guys have to take into consideration that lag is not always a bad thing. Take drag: if you develop 700hp@1200rpm, you're just gonna burn tires through the whole drag. However, if the power mostly comes in the high band of the rpm range, you can start without burning rubbers, and manage your rpm so you always shift when you know it's gonna be best for boost.
Old Mar 5, 2005 | 10:40 AM
'treezy's Avatar
QUOTE (redturbulance)
JD
lol......what's rain JD?
this weather is awesome!
Yeah, this set-up isn't that uncommon on Mr2's (there's a few nice MR2's around here, one that looks like that). I really wanted one of those (it was either an Mr2, older Supra, or Tib).
JD, check your pm if you're still on.
