Beta 1 2.4L Engine head swap
Old Aug 23, 2004 | 09:30 PM
Default Re: Wiring for Extra Lighting
QUOTE (Dweet)
what year 2.4l did you look at? only the newer hyundai engines have the CVVT. Try looking at 2001's and older.
I thought the 2.4L was new? The one I looked at was brand new at the dealer so I couldn't even see under the engine cover. I'd say take that engine cover off really quick and take a look. What year is your dad's?
I'd really like to see this.
Old Aug 23, 2004 | 09:35 PM
Dweet's Avatar
Default Re: tweeters
my dad's santa fe is a 92. i do have a spare beta on an engine stand liek i said before that I can tinker with if I get ahold of a 2.4 head. Ill tackle this one for sure once the elantra is finished.
Old Aug 23, 2004 | 09:40 PM
Default Re: Beta 1 2.4L Engine head swap
they made santa fes in 92? :? 8O
Old Aug 23, 2004 | 09:44 PM
Nope, not according to common sence, or KBB.com
Dweet, maybe you should start even simpler/cheaper. Get a gasket for the 2.4 and see how it matches.
Old Aug 23, 2004 | 09:54 PM
01roller's Avatar
the old sonatas had 2.4's back in 89-91 .....but they sohc .....
Old Aug 23, 2004 | 10:31 PM
2001Silvertib's Avatar
Default Re: Calipers
it might be possible...the honda crowd does it all the time... 2.0 heads on a 1.8(called a frankenstein)... 2.0-2.4 is kinda a big jump though.... i did something SIMILAR to my old crx i had a 91 honda crx si and i did what they call a MINIme swap to it. It involved removing the stock 1.6l sohc non vtec head and replacing it with a 97 1.6 sohc vtec head. It required new headgasket(thicker to lower the compression since it jumped it up to almost 13:1 if i remember right...been a while) new timing belt from the same year engine as the vtec head, an rpm activated switch to activate the vtec, and a couple other things. This swap actually gives you more power than swapping the entire vtec engine. raised it from the whole whoppin 108 it was before to 137... the 97 honda vtec motors only had 127(if i remember right)
Now the only problem i could see is that 2.4 compared to 2.0 is HUGE... also the studs might not line up... also is the 2.4 also dohc? it's NOT gonna work if it's a sohc like alot of older engines are.
now i was pondering doing a mini me swap to a beta from a beta 2... i know the beta 2 has less hp than the beta 1 but from what i understand the blocks of the beta 1's are designed better than the beta 2's. They should bolt up (practically the same engine) All you would have to do is get an rpm activated switch(30bucks from summit) to activate the variable timing or what ever it is on the new beta's.... it might be more worthwile and cheaper and easier to do this than swap the 2.4 head.
just some 2 cents as an old honda gear head
oh yeah the honda crowd also swaps dohc 1.8l heads onto dohc 1.6l blocks
called a minifrankenstein
heres a link to how to do a mini me swap to a crx... alot of the things might be able to be applied to hyundais..
http://crx.honda-perf.org/articles/z6swap/z6swap.html
Old Aug 23, 2004 | 10:41 PM
wattsup4800's Avatar
so what are we going to call our swaps
Old Aug 23, 2004 | 10:47 PM
Default Re: Custom Short Shifter.
if i was to do the beta 2 to beta 1 i'd call it beta 1.5.... but thats lame... i unno... a chop job? or.... 2.0 to 2.4... muttswap
Old Aug 24, 2004 | 05:32 AM
Dweet's Avatar
Default Re: Insomniac Thread
QUOTE (tibby01)
Sorry its an 02.. the 0 key is right next to the 9 key and my gf was probably naggin me for being on the computer while she is home and i wasnt paying 100% attention to what i was typing.
2.0 to 2.4 is doing all the time in the DSM work between the 4g63 and the 4g64.
Old Aug 24, 2004 | 10:33 AM
Jaws021's Avatar
Default Re: What do ya think
ummm guys
i already did the beta I to beta II swap
I have had a beta I with beta II head
Beta I with beta II pistons
My current engine is another hybrid.. but at this point, i dont remember what exactly came from what year..
I can write up an article on the various differences between both betas. I think i did this before... but i remember most of it.
Ill try and write up another post later tonight.
I think im the only on here to blow up both a beta I and beta II engine
