Arp Head/Main/Wheel Studs
Old Jan 3, 2006 | 11:32 AM
  #31
JonGTR's Avatar
Just cleaning up the part info and getting it together in one last post. Part #'s are in the parenthesis.
If you want a head set, you'll need:
"AM 4.500-1LB" Qty 8 (M10x1.25 studs)
"200-8519" Qty 8 (10mmID, .750"OD black washer)
"300-8343" Qty 8 (10mm x 1.25 12pt nut)
"AU7.250-1LB" Qty 2 (M12 x 1.25 studs) + nuts/washers
^^^Note: These last 2 studs are the 2 special ones that are 7.25" long. Be sure to get the nuts and several washers to offset the added length. I don't know the part #'s for the nuts/washers, but the salesman will/should.
If you want a Main Cap set, you'll need:
"AM 3.800-1LB" Qty 10 (M10x1.25 studs)
"200-8519" Qty 10 (10mmID, .750"OD black washer)
"300-8343" Qty 10 (10mm x 1.25 12pt nut)
Old Jan 3, 2006 | 12:21 PM
  #32
12SecRD's Avatar
how about adding your TQ #'s and if it was with Oil or Moly
Old Jan 12, 2006 | 07:56 PM
  #33
Denisst99's Avatar
on a side note i have a few rod bolts for the stock rods left
Old May 1, 2006 | 07:25 PM
  #34
Call_to_arms84's Avatar
Can anybody confirm the intake cam journal bolt sizes? I believe there is 11 of them, what is the actual measurements of the bolt.
Old May 9, 2006 | 05:48 AM
  #35
JonGTR's Avatar
The cam journal bolts aren't what strip. They're pretty tough. It's the soft aluminum head. I've had two holes strip from taking the cams out so many times.
If you want to know, then take one out. Takes 5 minutes. I've even run the motor with one missing. lmao.gif
I would just go with some stockers from the dealer.
Old Oct 3, 2006 | 09:34 PM
  #36
yamaha's Avatar
Vehicle: 2000 Hyundai Elantra
Does anyone know a website where we can buy these all from?
Old Oct 3, 2006 | 10:07 PM
  #37
Mad_john's Avatar
http://www.atomicspeedware.com/arphuyndai.htm
jongtr made the list and i had nick make it happen for us
he is cool as hell
Old Oct 3, 2006 | 10:14 PM
  #38
yamaha's Avatar
Is that for everything for the head, no rod bolts, Denis is getting me the hookup on those.
Old Oct 7, 2006 | 06:35 PM
  #39
LarryMcFly's Avatar
Talking ARP studs, anyone knows the part # for ARP wheel studs?
Old Oct 7, 2006 | 08:56 PM
  #40
Denisst99's Avatar
larry,
i could dig it up for ya
need longuer ones?
