Another Egt Probe Location Question
1. I'm not a NEW user.
2. the link that posted is not what I've been looking for. Also the post that you linked, I already read the post exactly 4 times now.
3. I wanted to know if the probe goes before or after the turbo not the cylinder numbers.
4. As I mentioned, I searched and found one post saying it could damage the turbo if the probe is located bofre the turbo. That's what I was not clear where to put the probe.
5. I searched all over the forum, and why you keep saying that I didn't search??
I spent 7 days to search and read all the posts here about turbo and related parts, and I even saved them in my computer for the future reference.
6. even after the intensive searching, I didn't get clear answers, and that's why I posted.
well..
1) then you should know better than to ask, when the relative answers are on the forums.
2-3) obviously, if you are supposed to put the EGT probe tapped into one of the cylinders that would be BEFORE the turbo. and you can look ALL OVER the internet, and find out this answer..
4) well you need to know crucial AND critical exhaust temps., and it was said by VIPER, who has a very advanced turbo setup, and loads of knowledge, that it SHOULD not be too far away from the cylinders, much less after the turbo, the temp. would be WAYYY OFF. and GARY, another turbo veteran, said where to tap it.. hows that answer NOT clear?
5) i didnt really say that, but your obviously not reading into it when you search or you would have this answer.. only thing you would have to debate, is to put the EGT in cyl 1 or cyl 4.
6)see above.
6)see above.
