Alternate Injectors - Mustang?
I've searched all the forums and the consensus seems to be that mustang injectors fit our cars. My question is, what year/models EXACTLY(mustang) will fit our fuel rail without any modification? (-taking into account impotence and size) Since the mustang injectors come in sets of 8, we'd be able to divi them up and get killer deals since they go for around $300 new. Thanks for the input.
What size injectors are teh Mustang ones and also since it will fit our Fuel rails will the Clips from our Tiburon plug right into the Mustang injectors?
Im looking for a good set of Injectors and wanted some feedback
Who sells good 650cc injectors
Guest
Posts: n/a
u should do what i am going to do.. im thinking your running standalone tho... i am running the dual fuel rail setup on mine and will have total fuel output of 600+cc.. my stockers are going to be run from stock ECU so i dont fvck with the ECU as far as fuel injection, and the other bigger 4 will be run soley thru the emanage and thru the MAP sensor..
as far as the aftermarket injectors, i would go for the mustang injectors they should work great.. im perdy sure the mustang injectors are around 290cc or so?
