Alpine Turbo Plugs??
Those plugs are 2 heat ranges colder, and should still do the trick. They are just the "cheaper" plugs.
The plugs I use are NGK V-Power Copper. Those plugs that you have must be the "base" NGK plugs. There is not THAT big of a difference between the two, stick with what they gave you, and then consider the V-power plugs after 20,000 miles when the plugs need a change.
