Alpine supercharger....anybody have one???
Old Oct 5, 2004 | 11:35 AM
  #21
FordFasteRR's Avatar
Default Re: help need cheap hp
Old Oct 8, 2004 | 04:20 PM
  #22
Default Re: FS: aftermarket steering wheel
Old Oct 8, 2004 | 05:31 PM
  #23
Default Re: Calling out javageek
As in SC?
God WHY???
Old Oct 8, 2004 | 06:15 PM
  #24
pros...
1. easy to install / remove.
2. does not require opening the motor.
3. gives instant torque / boost for my fav. kind of racing.
4. less complicated to work with, less parts as turbo...
5. ?
cons..
1. less power output as turbo.
2. less potential for more power if i want it later on..
3. impossible to intercool due to the manifold design.
4. ?
Old Oct 8, 2004 | 09:53 PM
  #25
Dweet's Avatar
Default Re: FS: Tigerlily Hyper U turbo motor
ehhhhh :?: :roll:
Old Oct 8, 2004 | 11:03 PM
  #26
Default Re: Wondering about haloz.biz
Cons
4. Maximum of about 40 HP gain.
I didn't know you had to open the engine if you went turbo. I thought that was just if you wanted to change compression or pistons.
As for constant boost, you can do that with a Turbo too, just set it to spool lower.
But it's your decision.
Good luck.
Old Oct 9, 2004 | 05:35 AM
  #27
Dweet's Avatar
Default Hallo from Israel!
well if you buy the alpine turbo kit you have to take the head off to put that decompression gasket on. Oh well, good luck bro
Old Oct 9, 2004 | 02:30 PM
  #28
Default Funny Dog
you cant set a turbo to spool lower, but you can buy a smaller turbo, or one of the garret gt series turbos. wink.gif
Old Oct 10, 2004 | 03:40 PM
  #29
ONLY1DB's Avatar
Default Re: FS: 15 inch rims not stock
that 40 horsepower figure was the old SC...this is a new design from what i have read/heard...so it could make more then that...it comes with 6psi and no need to open the engine.
Ford i'm with ya...cant wait for the install!
Old Oct 10, 2004 | 04:44 PM
  #30
Dweet's Avatar
Default Re: My aliminum crank pulley
6 psi *might* get you up to 200whp... thats if you have a good header and a good exhaust sytem
unless their new system ISNT a roots style blower
