Airram/65mmtb/new Manifold.
completely agree the top end HP is much lower than what I expected.
The engine has 2.00mm decompression gasket
garrett gt28rs t25 is rated at 300hp
the information I read on the garrett T3 super 60 is that its rated at 400-500hp.
Before the Turbo upgrade was started, I thought I would easily get 250HP
In the next 1-18 months i'm replacing various selected parts, starting from turbo manifold, IM, TB.
rods and pistons is going to be the very last one done.
Once I do the engine internals, this is almost like a brand new engine, except the cylinder head.
yep, the t3 super 60 will flow a little more though.
the decomp plate helps to explain, but you should still be making more. any fuel problems? got a dyno with af below?
the super 60 is rated more for around 350 max just like the gt28rs (they use the same compressor wheels)
DanielG made 288 whp with a regular t28 and a semi tuned car
the max I could get out of super 60 was around 265 to the wheels 290TQ .....maybe with a ported head and airram with larger exhaust system I maybe could have got 280 ISH
just be warned that most "super 60" sold over the web and in a few shops are in fact regular "60" t3 compressor
the "super 60" was a compressor made by turbonetics for the dodge 2.2 and 2.5 it's now used widely and often over used
Gary, DanielG made 288whp with a stock beta intake manifold,stock cylinder head,stock throttle body and low compression piston
How Do SOmeone can recognize a regular T3 and a Super 60??? for example my Compressor TRIM said A/R .60
RENANTE, do you have internal wastegate or the manifold that you are looking is for an external wastegate??
the compressor housing are the same from the outside
only the size of the inlet opening and the small diameter of the compressor wheel are different
the super 60 is a little bit larger
60 inducer 1.830" exducer2.367"
Super 60 inducer 1.900" exducer 2.367"
QUOTE (TiburonWao @ Dec 3 2005, 11:57 AM)
My turbo is internal wastegate.
I've already received the manifold from T4turbotiburon
The piping is much thicker and the design is completly different to my existing manifold on the car.
