Looking forward to receive all of these.
And see how much difference on torque and hp increase I get when installed. My car is running 210hp without major internal modifications at the moment. The Target is to get closer to between 250hp - 300hp 1 - manifold from T4turbotiburon. Received it this week, and the design is completely different and has thicker piping than the ones on my car, which is from ssautochrome. KSPEC PARTS 1 - 65MM tigerlilly throttle body 1 - airram intake manifold Just ordered them today and hopefully receive it in about 10-14 working days |
Let us know how it all goes. |
very nice! Any slips or video of the 200 HP? What do you have currently creating 210HP?
^ GT28RS at 16psi I believe... & some cams.
nice running it sounds like...keep stepping up, only one question--do you have a clean looking car?
i think that if you do both it gives the fact that you are gaining power in your an extra kick---i would like to see you exterior,interior, engine etc good work and good luck on the goal fing02.gif |
Exellent!!
Just remember that everyone here want to see a before and after DYNO HP with the AirRam and BBTB combo.... fing02.gif Good luck with your HP gains cool.gif cool.gif |
<div class='quotetop'>QUOTE (OzFxCoupe @ Dec 1 2005, 06:06 AM) <{POST_SNAPBACK}></div><div class='quotemain'>^ GT28RS at 16psi I believe... & some cams.</div>
that should be a whole helluva lot more than 210. awesome on the parts purchase man. christmas will come a little early for you! |
Yah he posted a while ago that he was running 16-17 pounds with only 210 hp and nobody could understand why it was so low, maybe he thinks its his intake manifold lol
The GT28RS is like a T3??? how many HP can he spect with 14-16 PSI???
BTW Renante.... put some pics and vids |
14-16psi is 14-16psi, regardless of what turbo is producing it. 14psi from a tiny turbo will produce the same amount of power as 14psi from a huge turbo.
14-16psi on a stock compression motor is high as fvck. pair that with cams and he should be way over 210. |
