1.8/1.8 Pistons And Rods
Old Jul 6, 2006 | 04:49 PM
daoust's Avatar
in korea , they use this setup for a long time because it is cheap and it is good for 400whp to 450whp
Old Jul 6, 2006 | 04:55 PM
GARY
if you use STOCK 1.8 rods and STOCK 1.8 pistons since the 1.8 is basically a destroked 2.0 it brings compression to about 8.1:1
i personally dont like this setup but hey if you wanna try it go for it
Old Jul 6, 2006 | 05:57 PM
12SecRD's Avatar
Huh?
Old Jul 7, 2006 | 06:36 AM
in the last post it sounded like you were tellin the guy that he should just use 2.0 rods cuz there the same strength as the 1.8 lmao.gif
Old Jul 7, 2006 | 03:54 PM
renante's Avatar
Try this reseller and worshop for advice and buying the parts.
They specialize in hyundai and mitsubishi.
http://www.rpw.com.au/
I purchased the following parts from them.
forged pistons, rods, rings, camshafts, ported cylinder head, valves.
My car is currently in the workshop for the next 2 weeks strengthening the engine with forged pistons & rods.
Everyone is saying is saying that the 1.8 litre engine with its stock rods is good for 300-400hp.
But 16psi, 300hp - 400hp its starting to get risky breaking the stock rods.
my original Turbo head gasket, 3.00mm composite graphite cracked at 20psi.
I've now replaced it with a metal gasket from this dealer.
http://www.importperformanceparts.net/
multi-layer steel gaskets.
if you're thinking about upgrading rods, pistons.
Then recommend to consider getting a steel head gaskets.
Old Jul 7, 2006 | 04:40 PM
swifty's Avatar
Does going with the shorter rod slow piston speed down? and allow you to rev higher?
Old Jul 10, 2006 | 02:39 PM
Mahonroy's Avatar
I was under the impression that the 2.0 pistons/rods combo was good for 350hp, and that the 1.8 pistons/rods combo was good for 450-500hp, and that no decompression plate/steel headgasket would be needed because with the 1.8 liter stuff that automatically lowers the compression down to around 8:1 right? Is this information correct? I am talking about OEM stock pistons and rods btw not aftermarket forged anything...
Old Oct 3, 2006 | 07:37 AM
Mad_john's Avatar
^ that is correct but you need to match the rings and check the pistons cleances as well
Old Oct 3, 2006 | 08:51 AM
homey14h's Avatar
mad_john is the place to get them lol
OT...mad...did you include rings in my set?!
QUOTE (Mahonroy @ Jul 5 2006, 01:43 PM)
Someone on elantraxd said that mad_john can get them for like $150? (Been trying to contact him about it but have not heard back, can anyone else get them?)
If you PM him he will get back to you in a day or two..if not..send another PM
Old Oct 3, 2006 | 10:19 AM
Mad_john's Avatar
a new set of rods and pistons at hyundai is 900 i say you got a good deal i also have to drive a 100miles
south to pusan get them
you guys are not paying for the
1. $8.47 a gallon for gas i burn a whole tank down and back that a $112.34
2. expressway costs and tunnal costs up and back $25.67
3. my time 4 hour of fight and drivein in korean traffic $ TBA
i never said 150 but you guys must take in accout that i have to convert our weak as dollor into korean money for the last 8 months the dollor in the shitter when you buy korean money with dollors it take more then say you buy dollors with korean money you use less korean money and this rate changes eveyday
elantraxd= fruitpies i had a asshole renig on an order because he could not put it on right and them bad mouth me for it...
when have i f*** anyone here
http://www.rdtiburon.com/index.php?showtopic=16784&hl
check the post above
