QUAIFE LSD
Old Mar 11, 2010 | 01:46 PM
iheartmyrd's Avatar
Vehicle: 1998 Hyundai Tiburon
Default QUAIFE LSD
so can anyone give me a definitive answer on what part number works in our
beta 2 Tiburon manual transmission
H-8B1 the actual Quaife vender says dose not exsits.
im not looking for a xxx.xxx.xxx number
im looking for quaife vender number similar to
the following vendor numbers shown.
Mitsubishi 3000GT NA FWD QDH7B
Mitsubishi 3000GT 4WD Front QDH16B
Mitsubishi Eclipse/Talon 4x4 (centre) QDH9B
Mitsubishi Eclipse/Talon 4x4 (front) QDH8B
Mitsubishi Eclipse 2WD 2000-2005 QDH7BR
Mitsubishi Eclipse 2WD non turbo T350 QDF3I
Mitsubishi Eclipse 92-99 2WD Turbo QDH7B
Mitsubishi Eclipse GT V6 6-speed 2006> QDH15B
Mitsubishi Lancer Evo 5, 6, 7 (centre) QDH11B
Mitsubishi Lancer Evo 8/8MR/9 (centre) QDH13B
Mitsubishi Lancer Evo 8/8MR/9 (front) QDH12B
Mitsubishi Pajero / Shogun (IRS rear) QDH10B
And also can anyone confirm that Mitsu Speedo gear Part#MD717879 is the right part number for the gear.
Old Mar 11, 2010 | 02:57 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
According to Kaaz's website, the Beta motored Hyundai's use the same diff as the '95+ FWD 4G92 powered Mitsu's. These include both the Mirage and the Lancer, but not the EVO's.
Old Mar 11, 2010 | 03:48 PM
The unit that people got to work in the RDT Definitive Quaife LSD Thread is the QDH8B.
Part numbers changed over time, but everyone in that thread got the Eclipse/Talon AWD front differential unit to work. That unit's current part number is QDH8B. Use to be 76.309.150.
The 48.309.140 and newer QDF3I part numbers are for the N/A Eclipse. It is highly unlikely that they will interchange as that's a Chrysler engine and transmission, same as in a Neon.
On a side note, I see that Quaife makes a LSD for the Accent? Wow, wonder how long they've been doing that. I have a new next mod! smile.gif
Hyundai Accent QDH4B
Old Mar 11, 2010 | 05:43 PM
iheartmyrd's Avatar
thank you very much, exactly what i was looking for.
