Level10, TC work...
Old Feb 13, 2003 | 08:01 AM
turbulence's Avatar
the tc wil not save you, regardless if you drive an accent or a tib.
Ok, I asked for suggestions on torque converters.
you're still missing the point, then. upgrading your tc isn't what your goal should be. you should be concerned with the tranny's internals itself.
Old Feb 13, 2003 | 08:22 AM
Shadohh's Avatar
Julez:
Just curious, but would the Valve Body Recalibration help the tranny then?
port them then recalibrate them.
Old Feb 13, 2003 | 09:04 AM
QS's Avatar
QS
Thanks Shadohh...
Old Feb 13, 2003 | 11:57 PM
Shadohh's Avatar
I seen a couple guys get work done by other shops. And they tranny just sucked.
It bucked on every gear shift, and caused a very rough idle. It seemed more like a drag tranny then a performance street tranny.
Levelten does some good work. You ever been in a car with just the torque covertor. It hauls *** right off the line.
If they were around when I sitll had my auto. I probably would tried that first.
Old Feb 14, 2003 | 11:46 AM
Julez's Avatar
Vehicle: 2008 Accent
I think I'm going to see what levelten can do, I would like to see them make new bands, clutches etc... too for it but well probably not.
Just anything for the auto would be good, like I've said in the past I screwed up regret my mistake, but am trying to live with it
