Fidanza Flywheel
Old Feb 12, 2003 | 06:19 AM
sharpshooter's Avatar
Default Fidanza Flywheel
Does anyone know if the pre 6/99 flywheel is the 35mm or 40mm. and yes i tried searching didnt find that info.
Old Feb 12, 2003 | 06:25 AM
Pre 6/99 is the larger center hole
Post 6/99 is the smaller center hole
Old Feb 12, 2003 | 06:36 AM
thanks random good catch i ordered one and had the wrong one on the way. hope i can get it squared away
Old Feb 13, 2003 | 12:06 AM
Koreandude's Avatar
PRE 6/99 p/n's for a Fidanza Flywheel for Tibs are 193241 just so you know for sure.
Old Feb 14, 2003 | 07:32 AM
Thanks koreandude the people i ordered it from were real cool and said even if i got the wrong one they would exchange it but the correct on is on the way now.
Old Feb 14, 2003 | 07:52 AM
Koreandude:
the PN for both is the same. That is why you have to specify the Pre 6/99 or post 6/99.
Old Feb 15, 2003 | 04:39 AM
Oh the guy i talked to said they had pn 193241 and 193141 so im not sure but i have the one i need.
