Flywheel Install $$
Old Dec 27, 2002 | 05:12 AM
Koreandude's Avatar
Default Flywheel Install $$
Hey i was told by a local shop the "book" requires 5.5 hours of labor for the install which comes up around $330 to install a flywheel. Is that right? How difficult you think it is to do on my own maybe with a friend? I have experience working on cars.. i've done Intake plenum swaps/injectors/lifters/cams and the such. My only problem is i don't have a lift at my house. What do you guys think?
Old Dec 27, 2002 | 05:16 AM
JAWS 021's Avatar
Thats about right...
You should take advantage at change the clutch as well
They have to remove the clutch anyways...
I dont recommend you do it without an engine lift...
When you pull the tranny, you leave the tranny with only 1 support...
Old Dec 27, 2002 | 05:36 AM
Koreandude's Avatar
you know, i would've done the whole flywheel thing about 10k miles ago when i did replace the clutch witha CM stage 1 and had my tranny rebuilt but as far as everyone knew there wasn't a p/n available for the pre-7/99 tibs or at least i didn't know about it. This sucks. I can obtain a lift from my dad but i've not the previous experience of doing a flywheel swap. Is it pretty straightforward? Heck, i mean webtech has been good to me so far when i replaced my struts and belts....Or should i shell out the $330 and kick myself in the head?
I mean I could do a whole lot with $330.00 like an UR underdrive pulley set, a SAFC, new paint for my front end, 2 car payments, it just goes on!!! Heck i don't mind sacraficing some blood and sweat. Dammit! Anyone have a good tutorial or good advice on how to do it??
[ December 27, 2002, 12:39 PM: Message edited by: Koreandude ]
Old Dec 27, 2002 | 06:49 AM
montanaqb16's Avatar
Dude do it yourself its not that hard
Old Dec 27, 2002 | 01:30 PM
Koreandude's Avatar
Yeah i called my best friend and we're gonna do it next sat morning. He's done it before on his escort (previously my escort that i sold him back in the day..lot of memories in that car *sniff*) So i'll grab all the trq. specs off of webtech and we'll sort the mess out. Wish i had a lift in my front yard though....
Old Dec 28, 2002 | 05:58 PM
FlyRyde's Avatar
Too bad you cant just have Jaws come over and help you out. Too bad, but your not alone. Im gonna pull the engine and tranny out. Then I get to pull that nasty lil canister out. If I can get ahold of the flywheel in time Ill do that too.
Hey Jaws should I got stage 4 while im at it. That **** felt like a beast and I was in the back!
